Hey!
So I figured I should make it official.
I don't plan on doing anything too fancy or over the top, most of what I want to do is performance related, that's it.
I'd love any input that I can get, because I want to do it right the first time.
Here's my goals:
275whp.
Better cornering, through suspension parts!
Cool, so here is my list of things (incomplete) that I am doing, or will do in the future.
Done:
Install Home Depot "performance" symposer delete.
Install AWR 88a RMM
Install Power flex passenger mount insert. With the bolt upgrade that I forgot to order with it.
Install Power flex transmisison mount insert.
"Install" CFM breather Oil cap.
Next up:
Install magnetic drain plugs for oil and transmission fluid. -- Got the oil pan one in. Looks like the transmission one hasn't budged in a loooonnnggg time. makes me nervous. Tranny oil change very soon
Install Intercooler and charge pipes, looking at whoosh V2, but shipping to Canada for that is a problem I suppose.
Front splitter, one of the smaller ones.
TODO:
2.
Install Mishimoto rad and rad hoses. This might be shunted down the list.
Install racing thermostat -- nope, this ones off the list
3.
Cross over pipe, brand ... Dunno. does it matter?
4.
Install ST Suspensions Anti-Swaybar (from and back) Or something better ... Suggestions?
Install POWERFLEX Fiesta ST Coil Spring Pads (front and rear)
5.
Install better brake discs on the front. They should hold up well at the track. Suggestions?
6.
Undo the muffler delete, or get a Miltek exhaust.
Performance catted downpipe.
Replace green filter on MAP intake, shove it into OEM air box. I don't know if that will work.
power adding mods:
7.
AEM / snow performance water meth injection system.
Ill probably buy this before hand, and play around with it before there are serious consequences if I make a mistake.
8.
X47R, or Whoosh motorsports turbo, which Ron should name the roadrunner (So I can get a $500 discount)
Blow off valve, wastegate controller etc..
Tunes:
daily driver tune,
high performance tune (one that plays nice with the water meth injection)
I have to do more research concerning the water meth in terms of the tuning.
TBH, the water meth isn't for more power anyways (in terms of a more aggressive tune) but as a cooling / octane boosting mechanism,
I'd like for the performance tune to handle the water / water meth, but not need it, even if it costs me 5 - 15hp.
optional:
9.
Clutch / flywheel upgrade
10.
Limited slip differential
Here's my car:
Here's my goals:
275whp.
Done:
Install AWR 88a RMM
Next up:
TODO:
2.
3.
4.
5.
6.
power adding mods:
7.
8.
Tunes:
daily driver tune,
optional:
9.
10.
Here's my car:
