Possible to run catless dp but with cat in place of resonator with o2 extension to lower under-hood temps?
danbfree
Tigard, Oregon, USA
Is it crazy to think that by moving the catalysts from the DP (run catless dp) to a high flow race cat converter in place of the stock resonator with an O2 with extension cable or something? Or not worth all the trouble for minimal temp reduction?
danbfree
danbfree
Tigard, Oregon, USA
Thread Starter #2
Not worth it, and would likely just cause you more headaches.
Proper function of a catalyst relies on retaining temperature in order to burn the emissions. In fact, the O2 sensors rely on this temperature as well but they are typically self-heating. The usual upstream placement of the catalyst near the engine is deliberate, to allow the catalyst(s) to heat up quickly, retain heat, and lower emissions more effectively. If you relocate the catalyst further downstream you'll likely interfere with its operation - not catastrophically, but in a way that would make it slower to reach nominal temperature and possibly trigger a code by causing the ECU to think that it's functioning below the expected efficiency threshold. Furthermore, depending on where you were to place the catalyst you may end up with more heat transferring into the floorpan or baking something that shouldn't be exposed to that much heat.
Basically, if you're THAT worried about temperatures from your catalyst you'd be better off just improving your cooling system, running catless and/or getting that section of your exhaust ceramic coated to trap more of the heat inside the exhaust itself.
Again, fantastic information from you! Thanks, that all makes perfect sense, sounds like literally ceramic coating the stock DP would be far easier with less headaches for about the same desired results.
danbfree
danbfree
Tigard, Oregon, USA
Very well said. I've always known that our factory exhaust is quite efficient. Seriously thanks for taking the time to provide so much of these details, it all makes sense. It's kind of crazy, on the Facebook groups people try to insist the stock DP is restrictive, they just don't get it. Dizzy makes the same ~315whp with an e20 tune on an x47r with a 100% stock exhaust, the same as those running 3" straight piped.
Sekred
Mid North Coast
I run a Catless DP with a 200 Cell Cat fitted where the resonator would usually sit. I running a BT with a blanket and wrapped SS manifold. My under bonnets are low, well below a stock turbo setup. No problems with a CEL but the vehicle runs a tune disabling the PID for catalyst efficiency.
danbfree
danbfree
Tigard, Oregon, USA
Thanks for sharing mate, cool to see someone actually has done this so my thought wasn't so crazy after all, and you did it the right way with wrapped turbo and manifold!
Sekred
Mid North Coast
I use to run a Catted CPE down pipe on the stock turbo. It would trigger a CEL after about 40 minutes of driving depending on conditions, highway or traffic so I think its very sensitive. My runs ok, no smell once it warms up. I would suggest theres no problem reaching light off temperature for the catalytic converter where its fitted.
danbfree
danbfree
Tigard, Oregon, USA
How did you hook up the O2 sensor and what tune did you have? From what I understand, whether you go catted high flow or catless, you either need to do a defouler spacer on the O2 or have it turned off in your tune... Anyway, I was assuming from the start I'd have to do this if I moved the catalyst further back with either an extension to an O2 sensor or just have it turned off in my tune anyway, but thanks for confirming your experience. After seeing more and more how the stock exhaust is so not restrictive pretty much at all, I don't think I'm going to bother with any more exhaust mods at all at this point.
danbfree
danbfree
Tigard, Oregon, USA
I would still recommend wrapping/coating your exhaust if you ever have the inclination. If you ever swap your turbo, that would be the perfect time to do so. Get a turbo blanket, too! Besides less heat being radiated from the exhaust/turbo, there absolutely are some performance benefits to doing so.
Not exactly related to this thread, but this has reminded me of the recent exhaust replacement I helped a friend with, on his R53 Cooper S. Besides the Borla catback system we installed, he had also selected long tubular headers that included a resonator that was more-or-less the same size and shape as the catalyst, but placed just slightly further back. I thought it was rather cheeky that they included a resonator like that. If nobody knew any better, it'd look like that portion was a stock system.
Great idea! If I do end up doing the turbo upgrade I'll ceramic coat the DP and ported manifold for sure...
Sekred
Mid North Coast
The O2 sensors were in the same place as the OEM down pipe, no tune at the time.
danbfree
danbfree
Tigard, Oregon, USA
OK, that totally makes sense then, if you used a defouler spacer along with high flow cats then you may not have triggered a CEL at all even without a tune.
