Register
User Tag List
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Member 230 Rep Points Krug's Avatar
    Ratings | Rate Transaction
    Member #
    10549
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Sep 2018
    Pontiac
    State
    MI
    Country
    United States
    Posts
    512
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    230
    I would still recommend wrapping/coating your exhaust if you ever have the inclination. If you ever swap your turbo, that would be the perfect time to do so. Get a turbo blanket, too! Besides less heat being radiated from the exhaust/turbo, there absolutely are some performance benefits to doing so.
    Not exactly related to this thread, but this has reminded me of the recent exhaust replacement I helped a friend with, on his R53 Cooper S. Besides the Borla catback system we installed, he had also selected long tubular headers that included a resonator that was more-or-less the same size and shape as the catalyst, but placed just slightly further back. I thought it was rather cheeky that they included a resonator like that. If nobody knew any better, it'd look like that portion was a stock system.
  2. #12
    Senior Member 397 Rep Points danbfree's Avatar
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    2,117
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    397
    Quote Originally Posted by Krug View Post
    Great idea! If I do end up doing the turbo upgrade I'll ceramic coat the DP and ported manifold for sure...
    '17 Magnetic - black wheels/red calipers - New Feb, '18.
    Tunes: Dizzy V2 e30/93 with Cobb TC at 3.
    Performance: Drop-in filter w/shroud cut, upgraded crossover and turbo inlet, symposer delete and hotside J pipe, TurboSmart VR2 electric recirc DV, 18" glasspack muffler swap with 9" resonated DC Sports black tip, step colder plugs.
    Mounts/bracing: Torque Solutions 75a RMM, Powerflex Street engine upper side mount inserts, TB Performance Traction Bar
    Interior: Mojo Mfg short shift plate, Savanini ball shift knob, upholstered leather padded arm rest.
    Lighting: Techmax proper reflector LED low beams, DeAutoLED bright white reverse and trunk LED's
    Next Steps: Intercooler, induction hose, tint, Eibach springs, hybrid, seats
  3. #13
    Senior Member 315 Rep Points Sekred's Avatar
    Member #
    62
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Sep 2013
    Mid North Coast
    Country
    Australia
    Posts
    1,312
    Mentioned
    26 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    315
    Quote Originally Posted by danbfree View Post
    How did you hook up the O2 sensor and what tune did you have? From what I understand, whether you go catted high flow or catless, you either need to do a defouler spacer on the O2 or have it turned off in your tune... Anyway, I was assuming from the start I'd have to do this if I moved the catalyst further back with either an extension to an O2 sensor or just have it turned off in my tune anyway, but thanks for confirming your experience. After seeing more and more how the stock exhaust is so not restrictive pretty much at all, I don't think I'm going to bother with any more exhaust mods at all at this point.
    The O2 sensors were in the same place as the OEM down pipe, no tune at the time.
  4. #14
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    2,117
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    397
    Quote Originally Posted by Sekred View Post
    OK, that totally makes sense then, if you used a defouler spacer along with high flow cats then you may not have triggered a CEL at all even without a tune.
Similar Threads
  1. Is the st hood same as normal fiesta's hood?
    By Clit_Beastwood in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 04-30-2018, 02:08 PM
  2. will running E40 or e85 tunes to lower track temps?
    By MegaBuster in forum Fiesta ST Tracking, Autocrossing & Dragstrip
    Last Post: 05-13-2017, 07:57 PM
  3. Replies: 0
    Last Post: 02-18-2017, 07:43 PM
  4. OEM black hood or Carbon fiber hood
    By ColoradoST in forum Want To Buy
    Last Post: 03-21-2016, 12:40 AM
  5. AEM intake temps
    By Natedogg in forum EcoBoost Engine Upgrades
    Last Post: 03-07-2015, 08:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
