Register
User Tag List
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member 31 Rep Points hendrixsrv's Avatar
    0%
    Rate Transaction
    Member #
    6657
    Medals
    Earned First 25 Rep Points
    Join Date
    Dec 2016
    Germantown
    State
    MD
    Country
    United States
    Posts
    95
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    31
    Car juttering/stuttering after putting my stock turbo back on.
    So, my x47r wasn't working on so I put the stock turbo back on. Everything is fine but during idle, the car would jutter/stutter every 15 seconds. Maybe it has something to do with the 14psi Turbosmart wastegate that was installed from the old turbo?
    Thanks!
    Sent from my SM-G955U using Tapatalk
  2. #2
    Senior Member 1173 Rep Points TyphoonFiST's Avatar
    Ratings | Rate Transaction
    Member #
    3563
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,043
    Mentioned
    44 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1173
    Quote Originally Posted by hendrixsrv View Post
    Thanks!
    Did you change back to stock tune?
    Is this your bush? Are you king of the forest?
  3. #3
    0%
    Rate Transaction
    Member #
    6657
    Medals
    Join Date
    Dec 2016
    Germantown
    State
    MD
    Country
    United States
    Posts
    95
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    31
    Yup, I did. The stuttering is gone I believe, now my problem is that the car is still pushing out white smoke and oil from the exhaust. I think it's residual oil from the broken turbo and it's burning it up and kicking it out. But still scary if it's more serious.
  4. #4
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,043
    Mentioned
    44 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1173
    Start it up and let that shit run outside for a bit ....then go on a Test beat!
  5. #5
    Senior Member 668 Rep Points Dpro's Avatar
    0%
    Rate Transaction
    Member #
    8838
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Oct 2017
    Los Angeles
    State
    CA
    Country
    United States
    Posts
    1,400
    Mentioned
    12 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    668
    White smoke not good. That is headgasket issue indicator i.e burning coolant/water Blue smoke is oil burning.
    2018 Orange Spice,Smoke Storm Recaro’s,Ebony wheels( for now) Thermal RD Exhaust
    , Cobb AP( tune by Randy af Mountune, more customs to come,)ST200 airbox with cold air intake,Revo foam filter, Whoosh/Ramair crossover pipe ,Whoosh Intake Tube,Turbosmart EV blowoff valve, Whoosh motorsports Symposer delete
  6. #6
    0%
    Rate Transaction
    Member #
    6657
    Medals
    Join Date
    Dec 2016
    Germantown
    State
    MD
    Country
    United States
    Posts
    95
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    31
    Quote Originally Posted by Dpro View Post
    White smoke not good. That is headgasket issue. Blue smoke is oil burning.
    I mean, the car was fine before I found out the turbo I bought had a bad seal. So I put the stock back in and oil and smoke is still spewing out of the exhaust. I didnt think a turbo swap would cause a gasket issue no?
  7. #7
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,043
    Mentioned
    44 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1173
    If his Turbo failed....it can Throw some of that right into the exhaust pipe....causing it to Smoke.
  8. #8
    0%
    Rate Transaction
    Member #
    6657
    Medals
    Join Date
    Dec 2016
    Germantown
    State
    MD
    Country
    United States
    Posts
    95
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    31
    Quote Originally Posted by TyphoonFiST View Post
    Ill definitely give it a tougher run once I get home. I'll update you in 3 days!
  9. #9
    0%
    Rate Transaction
    Member #
    8838
    Medals
    Join Date
    Oct 2017
    Los Angeles
    State
    CA
    Country
    United States
    Posts
    1,400
    Mentioned
    12 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    668
    Lol obviously, he stated White smoke. White smoke is not burning oil which is why I commented.
    No it should not but you stated your car was putting out White smoke. When a car has a coolant burning i.e. headgasket issue it puts out White smoke. When it is buring oil it puts a blueish tint smoke. Just trying to help you out here with clarification.
  10. #10
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,043
    Mentioned
    44 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1173
    But what also runs through the center section of the Turbo? Coolant....so it's a possibility when it failed....it got some coolant into the exhaust or it got in during install or removal.
Similar Threads
  1. Replies: 4
    Last Post: 11-25-2018, 12:27 PM
  2. Removed stock DV to install GFB, wrong GFB so I put back to stock - fluttering a lot now
    By Clit_Beastwood in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 03-25-2018, 11:19 PM
  3. Upgrading to NAV from stock Sony Sync radio and adding stock back-up camera.
    By CarGuy in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 08-10-2017, 12:40 PM
  4. Replies: 6
    Last Post: 06-19-2015, 11:34 PM
  5. Not giving up, putting one of these in my Duramax and pushing, digging, pulling for the ST......
    By RAAMaudio in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 01-09-2015, 10:14 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
