2014 Fiesta brakes and transmission lock
DanJS
HI - I'm having trouble with the switch connect to the brake arm (which I believe cancels cruise control) - when installed the brakes are locked and the car will not go into drive or reverse. If I take remove the switch out of the bracket (separate it from the brake arm), everything works normal and the brakes are released. I have tried replacing the switch but same result. Any help greatly appreciated...
