SLD 2014 FiST w/S280 Turbo, LSD, Recaro, BBK, Coilovers. Price Drop
Trader history for borg1087 (0)
Colorado Springs, CO, USA
2014 Fiesta St with 88,000 miles. I bought this from a fellow forum member in November of 2020. He did not tell me that the title was rebuilt at the time. It was hit in the nose, the crash bar had a dent in it when I pulled it off. Putting it on a laser frame aligner and suspension alignment machine, shows everything is at the correct angles and nothing is out of spec. It also has several braces and they lined up perfectly. I have just gone thru and changed all the fluids and all the maintenance items are all up to date. It doesn’t need anything! It drives perfectly I am an automotive engineer and this car was professionally build by Concours Motorsport and it is a fantastic car. All the modification have less than 12,000 miles on them. The compression test was all within 8 psi of each other and cylinder leakage test was less than 4% one each cylinder. The car was originally from California and now in Colorado, so it doesn’t have any corrosion or rust anywhere. It made 323whp & 317wtq on Edge Autosport’s dyno. If you are looking for a turn key FiST, this is it.
Modification list:
Engine:
S280 Turbo
Custom tuned by Alan @ Edge Autosport 323whp & 317wtq
Mishimoto catted downpipe
Mountune cross over pipe
Mountune silicone intake hose
Velossa big mouth ram air kit
ST200 airbox
ITG filter
Mishimoto catch can w/ check valve
Cobb intercooler
Koyorad radiator
Mishimoto oil cooler w/thermostat
Whoosh Motorsport cold side charge pipe
Driveline:
Quaife LSD installed by Puma Speed in a low milage gearbox
ST200+ clutch and pressure plate
New OEM slave cylinder
Whoosh Motorsport shifter bushings
Vudu short shift kit
Cobb weighted shift knob
Chassis:
Cobb RMM
Vibratech driver and passenger motor mount
Pierce Motorsport 6 point brace
Pierce Motorsport strut top brace
Whoosh Motorsport trunk brace
TB Performance crash bar
Suspension/ Brakes:
Whoosh Motorsport 300mm bike brake kit
Focus SVT rear rotors and caliper carriers
Bilstein B14 PSS coilovers
Whiteline camber bolts
TB Performance torsion bar
2 sets of wheels and tires, MSW wheels w/ Continental DW and Sport Edition w/ BFG Comp 2 A/S Plus
HR spacers (10mm & 20mm) and extended lug studs
Body/ Interior:
ST2 Recaro seats from a FoST
Sync 3 updated head unit w/ apple car play & android auto
Reverse camera wired correctly
Euro spec headlights w/ DRL wired correctly
LED high and low beams
Diode Dynamics fog lights
Cut out grille for more air flow (does not overheat ever)
Extras:
Original gearbox
Original Turbo
Original front seats
Spare original back seats
This is a very well built FiST as evidence by this list. I am not looking for anyone to lowball me or joy riders. I am happy to answer any questions about the build. This car works perfectly and I want someone that will enjoy and appreciate all the work that went into building this car.
Please feel free to reach out
Located in Colorado Springs, CO
$16,000
Brett
719-510-8080
55F5953D-B1DF-4BF4-9FCD-32975CFBE668_1_105_c.jpeg IMG_2124.jpeg B8981089-4946-4CF9-AC16-F75E5FFA5F28_1_105_c.jpeg 55F5953D-B1DF-4BF4-9FCD-32975CFBE668_1_105_c.jpeg IMG_2111.jpeg IMG_2112.jpeg IMG_2113.jpeg IMG_2114.jpeg IMG_2115.jpeg IMG_2116.jpeg IMG_2117.jpeg IMG_2118.jpeg IMG_2120.jpeg IMG_2121.jpeg IMG_2123.jpeg IMG_2124.jpeg IMG_2125.jpeg IMG_2126.jpeg IMG_2127.jpeg IMG_2130.jpeg IMG_2131.jpeg IMG_2132.jpeg IMG_2133.jpeg IMG_2134.jpeg IMG_2135.jpeg IMG_2136.jpeg
