2014 issues to look out for
MNK
Charleston, SC, USA
Looking into a 2014...
The VIN does not appear to be in the recall group for the engine coolant /fire issue... Have the VINs outside of this recall been fairly problem free?
VIN does pop for the the door latch recall.
Anything else I should be looking out for the in 2014's? TIA!
CarGuy
Daytona Beach, FL, USA
It's likely already had the recall done. My 2014 had its done and I can send you pictures of mine to compare. I wouldn't be afraid of a 2014 model. I've had good luck with mine. You can update the Sync to Sync 3 and install the backup camera or if you keep the Sync 2, you can add NAV.
CarGuy
The biggest issue for any year of them is blend door actuators and they are fairly easy to replace and not too expensive.
