Hey guys I have a 2015 Ford Fiesta st I am working on. Has 64k on it and vehicle is bone stock. It will over heat after normal operating temperature is reached with the a/c on. It gets up to 224 degrees and then goes up higher on acceleration until it reaches 240. I can then turn the heater on and it will slowly decline in temp. So I replaced the thermostat when removing the thermostat I found the spring retainer piece just laying there and the spring detached, replaced thermostat bled system. Went out to test drive and still same condition I have read things about radiator blockages and cyc 4 problems I am going to do a block test tomorrow and hopefully that gives me some insight. Any ideas or problems/fixes you guys have had for yours? Thanks
