Register
User Tag List
Results 1 to 4 of 4
  1. #1
    Member 6 Rep Points
    0%
    Rate Transaction
    Member #
    10060
    Medals
    Earned First 100 Posts
    Join Date
    May 2018
    Vero Beach
    State
    FL
    Country
    United States
    Posts
    102
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    6
    Intercooler upgrade without removing front fairing?
    Is it possible to do an intercooler upgrade, without taking all the front plastics off?
    Also, would you recommend an intercooler upgrade, to fight summer (100+F) heat soak?
    I already feel the ST has less power when the temps reach 90F vs when 75F.
  2. #2
    Member 93 Rep Points
    0%
    Rate Transaction
    Member #
    8663
    Medals
    Earned First 100 Posts Earned First 25 Rep Points Earned First 50 Rep Points
    Join Date
    Sep 2017
    Pleasant Hill
    State
    CA
    Country
    United States
    Posts
    320
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    93
    Quote Originally Posted by MeeLee View Post
    You need to remove the bumper to replace the intercooler because you need to pull it forward to get it out. If you're experiencing heat soak, then upgrading the intercooler is the cure; upgrading the radiator is also a good idea.
    - Mountune RMM, Quick Shift kit, SS brake lines, radiator, exhaust hangers, induction hose, FMIC
    - Koni Sport struts, Swift springs, Enkei RPF1s, Conti ExtremeContact Sports
    - StopTech slotted rotors, Carbotech 1521 pads
    - Pierce 2-pt chassis brace
    - Hotchkis rear anti-roll bar
    - Green air filter
    - Ford carbon fiber shift knob
    - Radium catch can
  3. #3
    Senior Member 1237 Rep Points TyphoonFiST's Avatar
    Ratings | Rate Transaction
    Member #
    3563
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,235
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1237
    Does a bear poop in the woods? Yes the front bumper comes off during install...very simple after you've done it a few times. I'll put money on it I can remove mine in under 10 mins.
    Is this your bush? Are you king of the forest?
  4. #4
    Member 284 Rep Points Quisp's Avatar
    0%
    Rate Transaction
    Member #
    3955
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Nov 2015
    Davenport
    State
    FL
    Country
    United States
    Posts
    981
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    284
    Sawzall
Similar Threads
  1. Is removing the front grille without taking the bumper off possible?
    By codestp202 in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 11-28-2016, 12:23 AM
  2. Removing honeycomb front bumper grill ?
    By j2FiST in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 03-11-2016, 10:44 AM
  3. Removing Front Grill ST Badge
    By GoMax in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 09-28-2015, 06:12 PM
  4. Replies: 16
    Last Post: 09-02-2014, 05:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
