Welcome to Fiesta ST Forum, is this your first visit? Click the "Create Account" button now to join.
Register
See the top rated post in this thread. Click here
User Tag List
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Senior Member 1238 Rep Points TyphoonFiST's Avatar
    Ratings | Rate Transaction
    Member #
    3563
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,237
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1238
    A group 48 Battery? Oh yes it can be done!
    Guest-only advertisement. Register or Log In now!
    As stated I installed a Group 48 AGM battery I got from Autozone over the Group 96 that came from OE. It was a very....very Tight fit with some adjustments made it will fit into the Tray. I think it would be easier with an open Style CAI also as I used my ST200 Airbox. Just thought I'd put it out there that it can be done....to those of you who said it couldn't....EAD.
    Is this your bush? Are you king of the forest?
  2. #2
    Member 63 Rep Points maestromaestro's Avatar
    0%
    Rate Transaction
    Member #
    2565
    Medals
    Earned First 100 Posts Earned First 25 Rep Points Earned First 50 Rep Points
    Join Date
    Apr 2015
    Houston
    State
    TX
    Country
    United States
    Posts
    429
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    63
    Yes. But - why? What's the difference between the two groups other than the size?
    Sent from my Pixel 3 XL using Tapatalk
    Stage 3 2015: Cobb FMIC + APort&Tuner + Cobb RMM + Ingen CAI + ATP charge pipe + 2JR catless DP + 3" inch Ingen exhaust/custom 3" flange for DP + Mishimoto Radiator + Mishimoto Oil Cooler : Sympozer delete : Boomba shifter bushings/short throw adapter : Wilwood Big/Brake Kits on all 4 corners and Timken rear hubs : Willwood Spec 37 slotted rotors; 4x100 bolting pattern conversion : Boomba Brake Cooling Deflectors : BC-2 Coilovers and Springs - 1" lower : TB Performance brace, crossmemeber and rear traction bar : NoPistons dead pedal : Euro smoked LED tailights : Strobe 3rd brake light :Rally Mud Flaps : Sanded front grille honeycomb : Auxbeam® 7" fog lights : Piercemotorsports front tow hook : SYNC 3 conversion with Android Auto/Apple Car Play : Rear view backup camera : Speed Dawg shift knob : JL Audio JX400/4D 4-channel amplifier : KICKER 11HS8 8" 150W Subwoofer : AudioControl LC2i 2 : Infinity 6-1/2 Inch Coaxial Speakers : Polk Audio Speakers : Schroth Rallye 4 ASM harness +...
  3. #3
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,237
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1238
    Quote Originally Posted by maestromaestro View Post
    I'm in Minnsnowta....cold weather..Good CCA...Its AGM and it was gotten for around $120 w/tx ....where AGM style batteries under even $150? No where....plus I also got to keep my OEM battery and try to bring it back after being in the Black eye area for some time.
  4. #4
    0%
    Rate Transaction
    Member #
    2565
    Medals
    Join Date
    Apr 2015
    Houston
    State
    TX
    Country
    United States
    Posts
    429
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    63
    So - you just happened upon a cheap AGM and it was only available in that size? That's the motivation?
  5. #5
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,237
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1238
    It was the closest in size to the Stocker and it's a decent battery for a great price. Plus its coming up on 4 years for me....so I'm staying ahead of the curve....if ya get me !
  6. #6
    0%
    Rate Transaction
    Member #
    2565
    Medals
    Join Date
    Apr 2015
    Houston
    State
    TX
    Country
    United States
    Posts
    429
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    63
    I am going to ask one more - just to see what GIF you're gonna use... (do you have a library of these handy, I guess?)
    I hear you about a good battery for a great price - especially if you want to replace the old one. But - there are multiple threads on the light-weight Odyssey or XS Power, you know, what with the hp/lb... You went in a different direction, clearly.
    Click image for larger version.
  7. #7
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,237
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1238
    Yeah I've had all those batteries at one point in time in other vehicles I own and have a hard time now coughing up $200 dollars for something that's quality has gone down as I've noticed due to being produced in other countries now....cough....cough.... like Optima. the only company I would maybe go with is a Deka battery next maybe...I Chose my Gifs wisely like Indy and the Cup of the covenant!
  8. #8
    Member 104 Rep Points nickstewartroc's Avatar
    0%
    Rate Transaction
    Member #
    4176
    Medals
    Earned First 100 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points
    Join Date
    Dec 2015
    Mount Dora
    State
    FL
    Country
    United States
    Posts
    444
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    104
    I know I'd rather go with the one OP posted than one of those lightweight batteries, between the price and wanting to have a battery be reliable/last here in Florida and not worry about whether my car is going to start, and also be able to have extended time with it on but not running. Not sure why all the negative in this thread over what OP did, I'm glad to know I can get a cheaper AGM and throw it in when my battery dies, which again thanks to Florida should be any day now...
  9. #9
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,237
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1238
    The main reason I did this was that it's coming up on 4yrs....its an AGM series battery and there aren't hardly any 96 series batteries out there in a performance variant. If anyone wants to go this route contact me and I'll share how it was done....it took some minor adjustments. Thanks Nick!
  10. #10
    Senior Member 1325 Rep Points M-Sport fan's Avatar
    Member #
    4438
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points Earned First 5000 Posts and 500 Rep Points
    Join Date
    Feb 2016
    Solebury
    State
    PA
    Country
    United States
    Posts
    7,592
    Mentioned
    35 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1325
    Quote Originally Posted by nickstewartroc View Post
    YES, heat does kill batteries quicker than the cold does, but we in the colder climes really DO need those full, factory level (or above) CCAs, reserve capacity (especially if one listens to the radio with the car off!), and Ah ratings, which the light weight, much smaller, AGMs do NOT provide.
    The ONLY way to get full power/factory specs (or close to it) AND very light weight, currently, is with one of the small, under 10Lb. LITHIUM batteries out there now, but these co$t 3-4 times as much as the Odysseys do, BEFORE you even buy the requisite, bespoke charger for them. [
    I will try to extend the life of the factory Motorcraft flooded lead acid deal out until the release date of the Odyssey 96R (hopefully SOON!), which will be the ONLY real 96R sized AGM on the market (believe it or not, given just how many cars use that size).
    At this point, I do not even care IF it is 10 lbs.+ heavier than the factory battery (but I am hoping it is NOT!), since I do not want to deal with a flooded lead acid battery going forward. ;)
    Magnetic 2016 Fiesta ST base model
Similar Threads
  1. Group 47 AGM battery conversion
    By romancommander in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 03-21-2019, 02:34 PM
  2. How to create group or join group (indy)
    By CGLENN27 in forum Forum Help Center
    Last Post: 12-29-2017, 05:28 PM
  3. Low Battery
    By D1JL in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 11-15-2017, 11:29 PM
  4. Replies: 451
    Last Post: 11-03-2017, 09:31 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
