Register
User Tag List
Results 1 to 10 of 10
Thread: Permanently overheated???
  1. #1
    Member 39 Rep Points reracer's Avatar
    0%
    Rate Transaction
    Member #
    1614
    Medals
    Earned First 100 Posts Earned First 25 Rep Points
    Join Date
    Oct 2014
    Wildomar
    State
    CA
    Country
    United States
    Posts
    160
    Mentioned
    3 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    39
    So I was cruising down the freeway and my car suddenly overheated and immediately went into limp mode where the car wouldn't rev above idle. When I popped the hood it all looked totally normal. The coolant was a little low, but not empty. I had the car towed to my apartment, and after a few hours the temperature gauge on the dash still read max temp. The next day the temperature gauge STILL read max temp. I'm assuming the coolant temperature sensor, or the cylinder head temperature sensor, or both went bad. Anybody heard of this?
    Also the car starts and runs just fine, but after a few seconds starts to idle roughly, and won't rev above idle. I don't know if that natters though. I'm assuming its part of limp mode.
    Any help is greatly appreciated.
  2. #2
    Administrator Staff Team 1488 Rep Points Fiesta ST of the Month Winner D1JL's Avatar
    Ratings | Rate Transaction
    Member #
    879
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points Earned First 5000 Posts and 500 Rep Points
    Join Date
    Jun 2014
    SFV, So.Cal.
    State
    CA
    Country
    United States
    Posts
    5,430
    Mentioned
    86 Post(s)
    Tagged
    2 Thread(s)
    Likes Received
    1488
    You are correct, a coolant sensor failure could be your problem.
    If I were doing the testing I would use a sensor simulator because I have one.
    The simple alternative would be to replace the sensor as they are cheep enough and go from there.
    Of course I talk to myself, sometimes I need expert advise.
  3. #3
    Member #
    879
    Medals
    Join Date
    Jun 2014
    SFV, So.Cal.
    State
    CA
    Country
    United States
    Posts
    5,430
    Mentioned
    86 Post(s)
    Tagged
    2 Thread(s)
    Likes Received
    1488
    BTW:
    There is another easy test you can do.
    If you remove the two wire connector from the coolant sensor (ECT) and then turn on the car but do not start, the gauge should go to cold.
    You should now be able to start the car and it should run normal.
    However, it will set a code and turn on the check engine light.
    With the connector removed from the ECT you could short the two wires together and the gauge should go to full hot again.
    The ECT sensor is on the driver's side of the car (USDM), on the end of the head toward the rear.
  4. #4
    Senior Member 1237 Rep Points TyphoonFiST's Avatar
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,235
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1237
    Quote Originally Posted by D1JL View Post
    Where did you get this sensor simulator? Id like to add one for this purpose!
    Is this your bush? Are you king of the forest?
  5. #5
    Member #
    879
    Medals
    Join Date
    Jun 2014
    SFV, So.Cal.
    State
    CA
    Country
    United States
    Posts
    5,430
    Mentioned
    86 Post(s)
    Tagged
    2 Thread(s)
    Likes Received
    1488
    Quote Originally Posted by TyphoonFiST View Post
    As a retired professional mechanic, I purchased it years ago from one of my tool vendors.
    The two I used the most were Snap-On and Matco, I am sorry I do not remember which one.
    The item came in a black box and I think was made by OTC, mine I am SURE is out dated.
  6. #6
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,235
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1237
    If its a good tool....It can never be out dated. Ive bought tools that are a decade old that can never be replaced also due to not being made but work better than the crap that is out now. Ill check out OTC...see if I can find it!
  7. #7
    Member #
    879
    Medals
    Join Date
    Jun 2014
    SFV, So.Cal.
    State
    CA
    Country
    United States
    Posts
    5,430
    Mentioned
    86 Post(s)
    Tagged
    2 Thread(s)
    Likes Received
    1488
    I do agree.
    Mine has got to be at least 25 years old and it still works great but I doubt you could find one like mine.
    I only meant that the new ones do so much more.
    I am not going out to my tool box at this time but I will look for a part number later.
  8. #8
    Member #
    879
    Medals
    Join Date
    Jun 2014
    SFV, So.Cal.
    State
    CA
    Country
    United States
    Posts
    5,430
    Mentioned
    86 Post(s)
    Tagged
    2 Thread(s)
    Likes Received
    1488
    @TyphoonFiST
    I was wrong, the manufacturer of my sensor simulator is Products Research Inc. (PRI).
    This is the unit I have.
    PRI SST
    As I said, mine is old and new ones may have more functions.
    This one just sold on 4/1/19
    PRI-SST-Sensor-Simulator-Tester-Older-Model
  9. #9
    Member 127 Rep Points
    Member #
    7895
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points
    Join Date
    May 2017
    Rock Creek
    State
    AL
    Country
    United States
    Posts
    613
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    127
    I was going to suggest this. The coolant temp sensor on my 95 z28 caused some retarded warm starts.
    2016 Shadow Black Fiesta ST
    Pollen magnet
  10. #10
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    4,235
    Mentioned
    49 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1237
    @TyphoonFiST
    PRI SST
    They are still out there! Noice....just gotta be quick on the draw !
Similar Threads
  1. Overheated
    By DloST in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 06-10-2018, 12:27 PM
  2. Car overheated with kids...
    By Truth in Ruin in forum General Automotive Discussions
    Last Post: 06-23-2017, 07:15 PM
  3. Car overheated...TWICE in 2 weeks
    By mossdahaus in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 07-21-2016, 11:26 AM
  4. Overheated again
    By blakewillingham in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 12-18-2015, 10:17 AM
  5. How to permanently enable reversing camera?
    By alex98uk in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 05-22-2015, 09:53 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
