225/45R16 tire pressure
Tumwater
I recently bought a set of Konig Dekagrams and I went with 225/45R16 Toyo Proxes R1R tires. I was curious about the "correct" tire pressure for daily driving. I know the stock pressures are 39/36psi but of course those are for the stock 205/40R17. Any help is greatly appreciated!
FiSTerMr
NYC
Stock pressures. Its not about the tire, but about the suspension setup.
Edit: I usually run a lb or 2 over stock, for a firmer ride, with increased steering response
San Francisco Bay Area
Can you post pictures of your setup? Stock suspension? Curious how 225's are working out for you since those tires are 9" wide.
Exumer
Reading
Same question. very close to doing the same exact set up with my dekagrams. Not too late to backout, so any experience you have with this and/or pics would be greatly appreciated.
K
Tumwater
Yes I am on stock suspension. No rubbing so far, I can go full lock in both directions. Only thing I haven't done yet is hard cornering on bumpy roads. I will post photos when I get access to my computer!
CSM
Cleveland, OH, USA
Any photos of setup?
JDG
Conshohocken, PA
You can do the chalk test to make sure you are wearing your tires evenly at your given pressure. I found that I could go quite a bit lower on the Dunlop Z3's in the same size as you. I think I ended up with 34F/36R hot.
