Virtual Dyno Results Thread
haste
Eastern
I swear I read somewhere the limit is 10 logs. I always delete them when I copy them to my computer so I've never run into an issue
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
Idk what the limit is, but it's def not 10. I have 8 times that on mine. [MENTION=688]Sourskittle[/MENTION] may have found a limit.
Sourskittle
Lakeland
I've stored way more than 10. The access port also stores tunes. So if you 20 tunes or more if could be eating into the datalog storeage space. I've never had that issue.
But.... I copy them onto the desk top so its not very often I go back later to get an older log off the AP.
Cyborg turbo, TBE, panda TR6 intercooler, drop in green filter.
245whp 293Tq V-dyno
13.3@104mph
twolf
Canton
If you look at the SS I posted there are only two tunes on the AP. I wish I'd known before I went out and did 16 logs, I would have brought my laptop with me.
dyn085
Vancouver
I log lots of five-minute files and it handles them well, though I've never tried to max out a certain number of them. Now I think I'm going to log my whole drive home from work just to watch Datazap stress over the size.
Hijinx
Auburn, AL, USA
Today I learned that the AP will only hold 10 datalogs regardless of length.
Scent from Glade Air Freshener
jeff
Evans
Hey folks thought I'd post this here. I've enjoyed using my AP and it's logging capabilities a bit more since my custom tune and have been happy to experiment with V-dyno as well. So today OTW to work I took 4 logs. All of these are within 5 minutes of each other on the same flat country road accelerating from 2500-ish rpm to redline-ish in 2nd gear.
I wasn't expecting them to be exact but the discrepancy has got me seriously mistrusting V-dyno for even a simple comparison of my own tune revisions. 25HP and 53 TQ differences between these logs! Crazy.
I need to put this car on a real dyno and see what the numbers are. Maybe next time I'm over near Atlanta I'll head to TopSpeed, they are swell folks and have done me well in the past.
dyn085
Vancouver
Yup, garbage in = garbage out. V-Dyno is just a math program; what you don't trust is yourself and your ability to keep the variables controlled.
Palm City
If you're experiencing wheelspin, I would throw that run out the window. You should probably try for some third gear pulls. Same road, same starting RPM at the same stretch of said road. As long as this is consistent, the only other variables are weather conditions which can be corrected for.
jeff
Evans
huh? How does what I posted have anything to do with garbage in garbage out? I completely trust myself and made it obvious that the variables were quite controlled. Not sure what you're saying here, I simply posted my 4 logs within 5 minutes...
jeff
Evans
That makes more sense, there was a bit of wheelspin but not much. I did 3rd gear pulls for my tune revisions but that's a bit harder to achieve, I was hoping 2nd gear pulls would work but with any wheelspin yes that is probably why I have such results.
I guess any datalog with any wheelspin does need to be tossed, thanks for the info.
dyn085
Vancouver
How many times have you seen a dyno operator do a dyno in the wrong gear, spin the tires, do it multiple times, then complain about the Dynojet/Mustang dyno not being trustworthy and assert that they did their best...even though you're looking at the chart that blatantly says otherwise?
twolf
Canton
Your weight looks kinda high to me which will inflate your numbers as well.
frankiefiesta
forked river
What's the fiesta st curb weight? I've seen 2720 and 2742 online. If Jeff weighs 220-240lbs his weight isn't too high.
Source: I weigh 220. Us chubby guys gotta stick up for one another
twolf
Canton
I used 2740.
I forget not everybody is small like me. Haha. I weigh like 105-110 depending on the day...
