koozy's ST
koozy
koozy
Los Angeles, CA, USA
Thread Starter #61
The Cobb downpipe is so pretty, too bad it won't be seen.
The intercooler swap was painless. I changed 2 factory bolts for some plastic supports for peace of mind.
Here's a shot of the OEM bolt and the clearance with the Airtec intercooler. It fits fine and I don't think there would ever be an issue, as everything is solid and does not move.
Here's the bolt, there's one on each side.
Here's what I replaced them with, they offer a tiny bit more clearance and not abrasive should contact ever occur. Bolts are from Home Depot.
Here's the clearance with the pan head bolt.
And here a shot of the center cradle mount that is removed due to the interference with the intercooler as depicted. Ideally the intercooler would be on top of the mount. It is possible to trim the mount to accommodate the intercooler if one chooses. This mount is not for the intercooler, it's for the plastic tray underneath. There's 2 other mounts that still support it fine.
the intercooler fitted and finished.
Stage 3 is awesome! Holly Mollie it rips now, what a difference from stock. The car is a total sleeper now. The intercooler can't be seen and the cat-back is still stock. To the unaware it looks totally stock. When the honeymoon wears off I may slip in an ATP turbo kit or other similar option that becomes available.
I finished up the down pipe installation today, which was over the course of several days whenever I could get time to wrench on it. There's an appreciation for doing the job myself, but if I didn't have the time or inclination to install it myself I'd pay the $200 I've read that some are paying to have it installed. The first time is always the longest, now that I've done it I can cut the time in half.
From the get go I was determined to pull the stock down pipe from the bottom. I knew it could be done from others who have done it, but no one really showed how. After spending about 15 minutes trying to figure out how to squeeze the down pipe out, bingo it comes out. It literally fell out with ease. I found the issue to be the 2 studs for the bracket that attached to the rear torque mount. The studs take up space. Several aftermarket down pipes have done away with these studs altogether making it easier to remove and install from the the bottom.
Here's a tip for anyone looking to remove the OEM down pipe from the bottom, drop the cat-back to get it out of the way and make sure the heat shield is off the converter, once the studs are over the power steering and front sway bar, position the 2 studs towards the driver side and pull the down pipe out.
Here's a shot of the 2 studs and the position the down pipe is in that allow it to come out from the bottom. It will fall right out without much effort, easy enough for me to put it back in and snap a shot of it.
Down the tunnel with the down pipe removed.
Cobb down pipe bolted in. Installing it was a breeze, since it's a lighter slimmer package sans studs compared to the stock unit. Installation is much easier without the bracket provisions. The bracket is on the OEM down pipe to help support it's weight. It's heavy compared to the Cobb unit, which does away with the bracket. Stock down pipe is 11lbs. Cobb is 7lbs. Also note that the OEM down pipe has notches on down pipe flange to turbo. This is to allow you to hang it on to the bolts during installation because of it's weight, making it a one man job and not two to thread the bolts in.
Kip2MyLou
Gaithersburg
#63
Nice write up. Are you not getting another exhaust because you want it to stay quiet? And are you getting the cobe intake?
Kip2MyLou
Gaithersburg
#64
Understandable. Sleeper is a good idea. I was going to go the downpipe first route and intake. Then exhaust later if desirable.
Kip2MyLou
Gaithersburg
#65
I thought so. Everybody is saying intercooler and they're probably right but I'd rather have downpipe and/or exhaust and intake before intercooler.
Kip2MyLou
Gaithersburg
#66
What made you go with airtec over cobb? And is the airtec a direct bolt on? No modification needed?
dwiechec
Huntley
#70
I was all in and waiting for Cobb to release their intercooler and would have gotten it, but the Airtec won me over with it's end tanks. I like how the flow in and out is more streamlined like the stock unit and not a hard radius out of the tanks. That said I'm down with everything else Cobb has available and those items will probably eventually end up on my car, but for now I'm enjoying it as a sleeper.
Yes the Airtec is a straight bolt-on, no mods needed.
Did changing the downpipe add anymore exhaust sound even though it's still the stock catback? Looking to do the same with my car!
Tehachapi
#71
I am not too far from L.A. county, and would be keen on attending a meet with some other STs so long as its on friday or saturday. I work a night shift so its tough to find the time. I haven't seen one other ST on the road yet, FoST or FiST.
koozy
koozy
Thread Starter #72
There have been meets here in LA County and Orange County, but for many people our counties are just spread too far and wide to make it realistically feasible to attend with schedules and traffic to consider. Hopefully in the future there'll be something and more frequent where people can attend at least some.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
#73
Four of us just went to Lake Arrowhead yesterday.
Dave
koozy
koozy
Thread Starter #79
Nothing obvious from what I can tell, but I haven't really spent much time with it. There was a small list showing what the update entails, but it seems like their website is inaccessible at the moment to see.
Kip2MyLou
Gaithersburg
#80
Okay. Thanks. I guess I'll have to wait until the server comes back online. It keeps giving me a server unavailable page when I try to log in and update.
