Some of you may or may not have seen this kit that is available for the Fiesta ST. We have been developing this Kit with Turbo Technics now for a good 12 months with some great results.
The kit consists of:
TT Designed Large Trim K03 Billet Impeller
TT Large Trim K03 Shaft Wheel Design
K03/K04 Frame Upgrade – Larger Shaft and Bearing Increase Durability and Reliability
Turbo Technics Uprated Thrust Bearing Assembly – All TT Design, Improves Thrust Loading Capability/Durability, thus Allowing Higher Boost & Flow to be Run Without Failure
Turbo Technics Designed Compressor Housing – Internal Geometry Improves Flow Capability and Compressor Efficiency, and Increased Inlet Size Improves Flow into Compressor Inducer
Our own demo car is fitted with the following modifications:
Cobra Sport 3 inch Decat System
Graham Goode CAIS
Jam-Sport Race Intercooler
Turbo Technics S242 Hybrid Turbo Kit
Maxd Out UK Remap
The car produces 311bhp @ the Flywheel & 310lbft Torque and this is still using the Standard Exhaust Manifold.
The Kit Comes with:
Turbo Technics S242 Fiesta ST Hybrid Turbo
68mm (Uprated) Silicone Inlet Elbow
Billet Aluminium Hose Joiner (Inlet Elbow to Top Induction Pipe)
2″ (Uprated) Silicone Boost Elbow
2″ (Uprated) Aluminium Lower Boost Pipe
Recirculation Solenoid Relocation Mount
2x Silicone Water Hoses & Aluminium Joiners
Stainless Steel Hose Clips (Jubilee Clips) for all connections
I've attached a couple of pics of the kit for you to all to see and the power graph.
Any questions let me know
Graham Goode CAIS
Maxd Out UK Remap
The Kit Comes with:
