What are the minimum thickness specs for the OEM front & rear rotors?
Brookeville
Greetings folks -
I searched and came up empty handed. I'm looking for the specs on minimum thickness for the OEM front & rear rotors. Also the run-in/run-out specs, if you have 'em. THANKS!
EDIT: 2014 FiST. :D
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
This is from the Service Manual.
Also covers non FiST
General Specifications
Item Specification
Front brake disc minimum thickness 0.827 in ( 21 mm)
Rear brake disc minimum thickness 0.354 in ( 9 mm)
Brake drum maximum diameter 8.661 in ( 220 mm)
Brake pad minimum thickness 0.059 in ( 1.5 mm)
Brake shoe minimum thickness 0.039 in ( 1 mm)
Brake lining maximum taper wear (in any direction) 0.059 in ( 1.5 mm)
Dave
