I installed my FSWERKS short shift and solid bushings today and all I can say is this was an awesome upgrade. It was pretty simple to install (once you got the intake, battery, and battery tray removed) and with short shift set on 25% reduction it makes a huge difference in driving experience, not just from a performance standpoint but even just for everyday driving. I would recommend this to anyone looking make their shifts more crisp and solid and the price wasn't bad either. Also with the install of the bushings, I found that I didn't need to remove the whole shift bracket. I just loosened all three bolts and one at a time removed each bolt and replaced the bushing then tightened them all down once I was finished.
One other weird thing that I noticed was that after I installed everything and put everything back together, I noticed that the auto up feature of my driver's side window no longer works. The auto down works just fine so I'm not sure what exactly happened during the install but I need to try to figure out what caused this.
