I just did mine today, along with the arm rest. Install is pretty straight forward and the installation guides that are floating around the internet are pretty comprehensive.
My only tip is to ignore the guides that say to remove the hvac panel to get to the shift boot, you don't need to do that. Pop the clips on that shifter surround, then pop the clips holding the black textured panels on either side of the surround. That allows you to lift the panel up and out of the way, with enough room for you to clear the front retention post on the boot frame and just wiggle it out the top.
Oh and the Charcoal leather is close to matching the Recaros, but if I could do it again I'd just go with black since that pretty much matches everything.
