A little dissapointed in the FiST 2018
Da9L
Randers NØ
Hello there, first post from me!
I've since i first saw the new Fiesta ST back in the beginning of 2018, had the idea, that this would be the car to replace my almost 20 year old faithful VW Polo 6N. The new interior and discrete exterior looks, was just the car i was looking for.
And a few days ago i finally had the chance to try one out at a dealer here in Denmark, although only a quick ride. And my thoughts? I was actually quite dissapointed in its power! Now, we were 4 people in it, and it was only a quick ride, but i want to give it another shot and try it again. I liked the handling and comfort though. How many RPM's does it performance peak in?
Later i tried out a Golf GTE, because a mate of mine wanted that car, so i just joined him to try and compare it to the FiST. This time we were 3 people in the GTE, but oh boy, that car was SO MUCH faster than what i remembered the FiST to be, and they have roughly the same HP (however the GTE has more torque since its a hybrid i believe). The GTE is also another class of car i know, and the pricepoint shows that.
But i still believe that i must have done something wrong on that day.. I tried out the normal Fiesta right after the FiST, but with the 1.0 Ecoboost 140hp engine, also with 4 people in it, and honestly didn't feel that much difference. What could possible have gone wrong, and shouldn't i give it another shot ? Any recommendations on how to drive it ?
Thanks in advance!
Saint Pauly
Yeap....dont pack it with 4 people....is it 2 door or 4 door? After I bought mine I got an AP3/ Cobb accessport....totally different animal. I'm not sure what they would use in Euro it might be from another vendor but similar. When you look at the price and compare the two...The FiST is usually the better bargin.
RubenZZZ
Montclair CA
The whole 4 passenger thing will affect performance. That an additional 500-600 extra pounds for the car to accelerate with.
Test drive it by yourself. Should be a different experience.
Sent from my 2PYB2 using Tapatalk
CarGuy
Daytona Beach, FL, USA
What everyone is forgetting is that he said the VW was a hybrid car. Hybrids have a huge torgue assist from the electric motor(s) and that torque is available at 1rpm so the hybrid will always feel faster with or without other passengers.
Ford ST
Pleasant Garden
Having people in the car makes a enormous difference it would be so much better by yourself. Let's not forget he is overseas so he is driving the new 2018 we don't get here in America.
Everything thing I have read and seen online says the 3 cylinder is fast as the old 4. Though it does have a bit of fuel saving technology that may have been the culprit in this. It will shiput down a cylinder and run on two when the ecu does not see the reason for running 3. Also the MK8 chassi/model ST has switchable modes of driving . I.E. Economy , Sports etc.... its very possible between 4 people and the wrong mode.
D
Da9L
Randers NØ
Hmm could maybe be that it was running on 2 cylinders only ? I did set it to sport, which made the exhaust louder, but really that was all it did. I didnt feel any difference in how fast it was. Have to try it with my self or with my wife only next time! And maybe ask how the cylinder disable works, so that i can make sure it is not that
Brooklyn
Why would you think you did anything wrong? It's a car. Nothing special you need to do except drive it and determine what you think about the experience.
Perhaps you just didn't like it? Nothing wrong with that.
DEss
CarGuy
Cylinder disable only works when there is a light load on the engine, i.e. at freeway driving, light load. Hills or a loaded car will not let it run on 2 cylinders.
neeqness
LA
I think that OP was probably running it at lower rpms which would keep the car running at 2 cylinders instead of 3. That would significantly reduce the power...besides OP did ask what rpms to run it at for more power.
Not sure for Euro model, but I would think that you need to have the rpms above 3k. Could play around with it next time to find out when it kicks in and see the difference then.
Clint Beastwood
Laguna beach
The st’s are only quick because they’re light and tossable- put 4 people in and you negate the virtue of the car. You can only do so much with 1.5 liters of displacement. Maybe put a second engine and trans in the rear hatch :D
3.0l twin turbo six cylinder with all wheel drive hehe
