Couldn't i also have them tune it now including the FMIC, knowing the cold season is on it's way and once i get a new IC, it's already in the tune? The worst that could happen is the turbo is pushed a bit harder than it would and get heat soak a bit sooner right?
While you technically could, you'll probably wind up trying to convince yourself you don't need the FMIC after all "because it's been fine so far". Just because you *can* run without the FMIC doesn't mean you should. If you want to be safe, follow the recommended/established upgrade paths - they're there for a reason.
There are a few reasons people encounter issues tuning:
- Not monitoring things they should be monitoring.
- Skipping "steps" recommended by the tuners. The tuners recommend them for a reason - sure, Cobb might be trying to sell you parts, but Dizzy and Stratified probably don't have that motivation. If they recommend an FMIC, it's because in their experience it's required for safety.
- Behaving impulsively.
Some people run tunes without the requisite mods and have no problems.
Some people run tunes without the requisite mods have problems.
There's no way to be certain you'll be "safe" without FMIC, ETC. Generally you won't have problems.... until you do.
Just remember you're building the car you want to have. The first step of building
anything is to make sure you have a solid foundation - cut corners with the foundation and no matter what you build, it could have issues down the road.
