I looked at it. The highest boost you hit was 23.17 with an afr of 11.91, which is fine. The tune you bought is ots it is meant to be conservative and caters to a lot of different climates and environments. My first suggestion would be to recheck your charge pipes, I would then look at your vacuum lines off of the turbo, and one off of the cold side charge pipe, also double check the lines off of your intake. if everything looks good. I would either try to reset kam on your accesport or I would reflash the map. Boost is based off of torque targets this car will only boost whatever it needs to see that torque target, this depends on the weather outside, the colder the air the less boost you will see because the air is more dense and it doesn't need big boost to hit that target. I would honestly say as well as long as your afrs aren't dropping down to Low 10s or going to 13s at wot you're fine. I remember on my stratified ots tune I would periodically hit 10.88 at wot.
