So if you have not read my build thread, just to give some background I like RAMMAUDIO, have extensive car and home audio experience. I have owned two car and home theater stores, competed Expert 601+ for 4 years in IASCA, Judged SQ for another 12, and have received full sponsorships from Pioneer, Nordost, A/D/S, and Kimber Kable, Dyomat, blah blah blah. Moving On.
So the problem has been how to get a really good clean signal from the head unit to an outboard processor or amp.
Option1, get the schematic from Ford and access the signal before it is sent to the speakers and before it is processed. This is not going to happen. There is the possibility that Downtown Radio (national repair center for oem radios), might be willing to give up the schematics but then if RAMMAUDIO cant make the modification we have to find someone and I am fairly certain he would not want to start up a radio conversion business. Maybe?
The dash kit that Metra Currently has on their website WILL NOT WORK. Trust me on this I tried. Yes its ugly but when you want the best sound quality, sacrifices have to be made.
When you pull the CD player out it appears to have the satellite radio antenna connected to it, and probably has the speakers coming out it, so it is self contained. I have not seen any posts here to indicate otherwise, so if I have misspoken I apologize.
Metra sources tell me a kit is in the works. But no one here seems to like the way their kits look.
Previously some have been doing a LOC from the rear speakers to a sub amp. Not a problem because 99% of what you are listening to is below 60 hertz provided that is where you crossed it over and although distortion is present not very audible at those levels.
If Sound Quality is what you are looking for, there may now be another option.
The JL Audio Clean Sweep was ok at best. It sort of worked, and there are a couple of processors out there like the Bit one that take a high level signal try to reprocess it back to flat. I was a dealer for Audison and from a usability standpoint, tuning with the Bit One is not hard. You need a scope with a 1hz tone on a CD (to properly set the gains), and an RTA (Real Time Analyzer). The PS8 from ARC, the MS8 from JBL, and even Audio Control has a piece, but theirs requires you make the adjustments.
JL Audio now has a device called the FIX 82. You feed it signals from the left and right front midrange which are full range signals because we have a wire that goes from there to a cap on the tweeter so it is crossed over at the source. One of the problems with the Ford Sync system is it requires a load to function correctly. You don't see this problem when just hooking up a sub or replacing speakers. JL Audio has a device called a LSA. The causes the system to see a proper load, then you run from their into the FIX 82.
You set the volume on your Sync system, insert a CD, and put the Fix 82 into learn mode. It not only corrects all of Ford's mess, but what you get on the other side is a completely flat signal to work with. Now, if you have been following RAMMAUDIO, he purchased a processor made by Precision Power. While the instructions say it is a 2-way, it actually is a 4 way. It has the ability to control not only a left and right tweeter, left and right midrange, but left and right mid-bass and 2 subs. I had the Bit One in my Corvette, and had purchased a PS8 from Arc Audio as RAMMAUDIO did, but we both sold ours just for different reasons, he thought is was more processing that what he needed. Fred Lynch at Arc helped develop that piece, and it has more processing than some small recording studios. I sold it because it was missing the bluetooth streaming module that they are never going to develop.
Here is where it gets really nice.
The FIX 82, has Toslink Fiber out. That means I can install this box upfront where the speaker wires are, and then run a fiber cable to the rear for the processor. Fiber is king. Now you get into a whole other world of audio geekdom. Do you use plastic or att glass fiber. Sorry I digress.
Anyway, some here are true OEM people. They don't want to lose any functionality of the factory system. Well, there is a downside to everything. As with the Bitone, and some of the other processors, there is a downside to the DSP-88R. When you send Fiber to the DSP-88R, you no longer have an analog signal and therefore no volume control from the head unit. That means no more steering wheel control for volume or from the factory dash location. But the DSP-88R does have a really small nice volume control to use. If you have competed at any time in your life and ever worked outside of the box to get the best audio possible from a bad situation, Mark Eldridge with the help of Gary Biggs, created a 4.5 inch billet aluminum volume knob. Every time I judged his car, I had to wipe my mouth. Imagine putting your whole hand on the center console to turn this thing. OMG. Anyway
You lose the Steer wheel controls for Volume and because the processing is volume dependent in the Ford Sync system, you cannot ever change the volume on the Ford System after installing the Fix 82. So when configuring it, you set it to something high like 75% which should be out of distortion range for the factory amplification.
Now it gets better. I am installing a 12" Ipad Pro in my car to use for work on a Stalk. There are hundreds of Digital to Analog converters to use with IPADS. It just so happens that the DSP-88R has a set of Analog inputs so your digital music just got 1000 times better than anything the factory system could put out. But you still get access to the radio, satellite, radio, Bluetooth phone, and CD from the factory system.
The only other downside is the DSP-88R only has 4 volts of output. But fear not, a nice set of Audio Control line drivers or from Arc Audio fixes that problem and that is something that is necessary when you have a pair of amps that will take 6.5 volts of input.![Cool [cool] [cool]](/images/smilies/icon_smile_cool.gif)
I purchased 2 Alpine PDX v9's. They are 100 x 4, and 500 x 1. JL Audio makes a new subwoofer called a TW1 in 10" and 12" and they also sell this in a prebuilt enclosure. But this is not any ordinary sub enclosure. The 10" enclosure is 21" wide, 12" tall and 6" deep. The Duel 12" is 26 x 14 x 8. That is really really small for what it is. It weights 50lbs. I am generally not a 12" guy from a SQ point of view, but these were really impressive sounding.
Now before anyone jumps on me about weight. I do not race my car. I do drive it aggressively and might take it to the track after installing the new turbo and adding 150 lbs to the car, taking out the spare and replacing it with a kit, and perhaps swapping out the crashbar, and having replaced the brakes, and struts with coilovers, it is not quite adding 150 lbs. If nothing else, it balances out the car more because of where I am adding the weight.
I'm still on the cliff regarding drivers. I had a complete set of K-2 from focal and I sold them. So for the bidbass driver I am either going to use a Morel 6" or a Dynaudio 6.5". Yes they are expensive, but I take sound much more seriously than I do anything else. They are about $350.00 each.
As for the midrange more than likely the Seas MU10RB-SL which is a 4" or the SEAS Prestige MCA12RC which is a 4.5". The tweeter will either be a ScanSpeak Illuminator D3004/6600 AirCirc Tweeter Textile Dome or ScanSpeak Illuminator R3004/6620-00 1" Tweeter - Black Face Plate. Yes they are pricey, but it would not be the first time I had gone there, but it very well may be the last. In a couple of months I will be leaving my Accident Photography job and moving out west. HEHE (dyn085), closer than you probably would want. Anway, I want to enjoy the car.
While some may ask why on the dash configuration, Let me include a picture.
This was my Fiero back in April 1998 and 1999. The one in Car Stereo Review, Car Sound of Japan an Car Stereo of the UK. Blah Blah Blah I know. The red thing in the floor covered up by the mat was the right side subwoofer port. The subs were in a 4th order bandpass enclosure in the front of this car. It hit so hard you almost felt like your heart was skipping a beat.
I intend to place either 2 4" or 2 4.5" midrange drivers with tweeter on the dash of this car. What you are doing is taking a D'Appolito configuration and turning it sideways. What it does is give you a recording studio monitor effect. Sort of in your face impact. The stage is not quite as wide as it would be with a traditional 2 way with tweeter to the far outside with mid-bass in the door, but the sound it creates is like nothing you have ever experienced in a car. This is why the car got so much attention. It had two tweeters mounted vertically and each one had a different crossover point so you could raise on lower the stage. What it also does is give you stupid depth, way beyond the windshield. The VP of design for Pioneer Electronics Worldwide sat in the car for over an hour at the Dallas Finals. He also got a little giddy about all of the work I did to upgrade the ODR processor output stage. Blah Blah blah. By they way, When I was done competing, Pioneer bought my processor from me.
Anyway, just thought I would share, this is going to happen very soon. Amps come today, Processor will be here in the next day or so. And doing all of this while still trying to finish getting the Turbo upgrade settled and tuned while trying to maintain a goofy conversation with Dyn085 and Hijinx, and VAFIST. Still love you guys. OMG its a lot.
![Shhh! [shhh] [shhh]](/images/smilies/shhh.gif)
