(Long Story) Going around a gentle corner at maybe 35-40 MPH I heard a "ting-ting" sound come from rear of the car and immediately thought I clipped the curb by a fraction and damaged a rim. It was near midnight, which I drive that area every night home from work and am always weary, but mistakes can happen. I was rewarded shortly after with a bit of wheel wobble.
I pulled into a parking lot and looked at all 4 corners, nothing looked chipped. I drove slow in the empty lot cutting left to right and the wobble got worse. Pulled out the mag light and found I was missing a lug nut on the right rear. Dug out the jack and wrench and found that the other 3 were loose! Man that could have been bad!
I tightened down the remaining 3 lug nuts while fending off a guy who "just got a new job but needs gas money" (South Main Street, Houston Texas, I've heard this story 6 times at least).
I limped home, checking the nuts again halfway home. At home I had more light and noticed the wheel was slightly crooked, I just knew I chewed up a hub centric ring, so I popped on Amazon and reordered the same set for $16, down from $22. Took the wife's vehicle to work until the weekend.
Just jacked up the car and popped the wheel off, took off the hub centric ring which looked only lightly scuffed, but noticed the inside of the rim had shavings. The hub of the rim had a lip on it all chewed up which i don't remember Lip! Looking harder, it was another hub centric ring that went unnoticed when the Ford Quick Lane did my oil change and tire rotation. So there were two rings stacked on top of each either and torqued down with all the fury a budget impact can put out. Which means also i have a wheel with no ring somewhere else on the vehicle...
I normally go to the original dealer Quick Lane in Rosenberg but I was short on time and used the Helfman Ford dealer Quick Lane on my way to work. I'll be stopping by there tomorrow to explain to the service manager how this could have killed me on the freeway instead of running my night. I'll also be telling them I need my money for the ring set, and if I have bearing problems within the next year from this being off kilter for a few weeks that there will be problems.
(Short Version) Ford Quick Lane "tech" didn't notice he had stacked one hub centric ring (that was stuck in the wheel from the front) on top of another ring (that was stuck on the hub in the rear). [emoji35]
Sorry to be long winded, pics to come in a bit.
Sent from my XT1254 using Tapatalk
