Boomba Racing Fiesta ST Rear Motor Mount
Trader history for Boomba Racing (0)
Boomba Racing
Wood Dale
BOOMBA RACING is proud to announce our new rear motor mount (RMM) for the Fiesta ST!
This direct bolt-on mount and bracket combine to replace the rear-lower engine torque mount, also known as a torque damper, significantly improving the vehicle’s traction and shifting response by reducing excessive engine flex. Wheel-hop during hard launches are also completely eliminated thanks to these mounts. Boomba Racing mounts are machined from high quality aircraft grade billet aluminum for strength, durability and looks. Inside each mount you’ll also find solid polyurethane bushings with the rigidity carefully chosen to optimize vehicle stability while also minimizing excessive vibration transfer from the motor to the body.
Installation is simple, does not require engine support and utilizes all OEM hardware. Mounts are available in Natural Aluminum finish as well as Red, Black & Blue anodized.
MSRP: $155.00
Boomba Racing Fiesta ST Rear Motor Mount - BoombaRacing.com
Water vibration Demonstration with Boomba Racing RMM installed!
0:19 - Engine Start
0:35 - Max A/C
0:56 - 1500 RPMs
1:00 - 2000 RPMs
1:05 - 3000 RPMs
[video=youtube;af6nhk0Tefs]http://youtu.be/af6nhk0Tefs[/video]
me32
fairfield
Looks very nice. How is the added vibration with this?
MOFiST
Adelaide
Good work guys. Love the colors!
Thanks for giving us another option.
Can you tell us the Durometer rating?
[like]
iso100
Price is matching Cobb's offering. It appears as though this one is going to be stiffer than theirs due to less material.
Is there a warranty of any sort?
Boomba Racing
Boomba Racing
Wood Dale
Not too bad! Increased vibrations are to be expected, especially at low RPMs and with a/c on, however once broken-in after a few hundred miles, its hardly noticeable! We feel the that any increase in added vibrations are well worth the performance benefits! We're actually working on a Jurassic Park-style Water vibration demonstration video to show you guys! Stay tuned!
[like]
We actually use a durometer rating of 80 in our polyurethane bushings. We found it to be the the perfect rigidity for race applications, while still very drive-able off the track!
Yes, our polyurethane bushings come with a LIFETIME warranty! IF they ever go bad, we'll pull them out and replace them!
iso100
Excellent! That's what I wanted to hear. It appears as though these made by pouring the liquid PU into the assembly. I was a little concerned about what happens in 30k miles...
Clarksville
Dude this is pretty sick. Sadly, I already got the Cobb mount, but like these guys were saying. Thanks for adding another option.
only 3 options (With 1 of them being super stiff and the other being directed towards the non ST fiestas), we needed some more.
And it's so shiny too.
Boomba Racing
Boomba Racing
Wood Dale
Thread Starter #13
Shot of our RMM, in Natural Aluminum finish, installed on our shop car!
Tarzana/Oxnard
This is the obvious direct competitor to the Cobb RMM based on the price and description. My question to Boomba Racing, then, is specifically why should I buy this RMM over Cobb's? What are its advantages?
Boomba Racing
Boomba Racing
Wood Dale
Thread Starter #15
0:19 - Engine Start
0:35 - Max A/C
0:56 - 1500 RPMs
1:00 - 2000 RPMs
1:05 - 3000 RPMs
MOFiST
Adelaide
Really? That seems like nothing. Did you notice any extra cabin rattles? Could be another order heading your way soon!
Boomba Racing
Boomba Racing
Wood Dale
Thread Starter #17
They make a great product as well, no doubt!
Our mount is a 2 piece design. We chose to include and upgrade the mounting bracket as well, so theres no need to pound out and re-use the OEM metal piece.
We have years of research and development in making motor mounts/torque dampers, going all the way back to 2003. Our mounts are regularly used in high HP turbo builds in the auto-x and drag racing community, such as SRT4s, Evo 9/X and turbo/supercharged Civic Si's, they were designed from the ground up take a beating while still maximizing performance. All of our mounts are designed, engineered and CNC machined right here at our Wood Dale IL USA facility. We use only high quality aircraft grade billet aluminum and top of the line 80 duromoter polyurethane bushings, which by the way comes with a lifetime warranty for the original owner. And even though you dont see it much, we offer the mounts in 4 different colors at no extra cost, for those that like to personalize. And of course, we back up everything with our excellent customer service, which is priority #1 to us around here!
No rattles on our shop car! Its been installed for about 300 miles now and has broken-in nicely!
iso100
So the install is likely quicker on this than on Cobb's?
Tarzana/Oxnard
Thank you for the explanation!
