The compressor housing is same as stock* I'll have to go out and measure the inlet after dinner if you can wait or maybe someone else will chime in while I'm at dinner.
In the meantime, did you check the usual suspects? Hot side charge pipe is common, symposer (or delete most likely), and the throttle body connection is one that eluded me for a bit.
