Center Caps for TD Pro Race 1.2
Santa Rosa
Anyone recall the bore size of the Team Dynamic 1.2 wheel or know where I can pick up some caps that fit them?
TDavis
Columbia
Following. 3 out of the 4 of mine are crappy looking. The liquid dome where it has the logo looks all scratched up when it shouldn't be. The other 1 is perfect though.
I tried OEM Ford ones but they're ever so slightly too small.
Capri to ST
CHAPEL HILL, NC, USA
I believe the hub bore size is 63.4 mm, which is the basically the same as the stock bore size, but I also found that the stock Ford ones were slightly too small.
Since they lost their US distributor, I contacted the factory directly a while back when I wanted to buy one more wheel. This is the contact email address I got off of the Rimstock site, they are the parent company of Team Dynamics-
usasales@rimstock.com
HAHAFiST
Santa Rosa
Much appreciated! I need to get a set of calipers myself. Also, as CAPRI mentioned, stock caps don't fit. I bet they're closer to 64-65mm. Looking for aftermarket caps as well.
HAHAFiST
Santa Rosa
I went through this a few years ago. Check out my thread. I ended with some cheap eBay centercaps and decals and they’ve been working fine through multiple summers and winters. I got clip size 55mm and outer cap size 57mm along with matching decals.
https://www.fiestastforum.com/threads/team-dynamics-alternative-center-caps-options.6099/
I remember that thread. None of the link is worked. Do you have a new one? I may just search for the measurements you mentioned. I’d like a perfectly flush fit to that center bore lip if I can help it.
