**Engine, transmission, and spoiler pending local sale**
Swapped out the original engine from our 2014 ST at 145k miles, ran like a champ but I had an opportunity to swap for a younger one while I was changing out the transmission. Also up is the transmission, I haven't pulled it apart yet but it had a pretty nasty input shaft bearing noise that mysteriously went away right before I swapped it and the fluid was verrrry sparkly, so I'd assume it is useful as a rebuildable core and nothing more. Also have a Tuxedo black painted OEM spoiler (one of the mounting points is broken, see pics in comment below), a complete subframe with suspension, front brake assemblies, electric rack, both drive shafts, etc. out of a 22k mile 2015 as well as a complete steering column with wheel and airbag, a starter, ECU, a radiator, an intercooler, 2 shifters, 2 sets of shift cables, clutch and gas pedal assemblies... basically a whole bunch of stuff I had to buy to get the engine and transmission. The engine runs great, alternator, turbo and AC compressor are fine. Downpipe flange on the turbo has a broken bolt stuck in there, did I mention I was doing this swap alone in my tiny garage? I'd like to get $600 for the engine complete, make offers for anything else. Pick up in zip code 19320, outside Philadelphia. A LOT of it is boxed up, so it isn't all in the pictures, but make me an offer for whatever you need, I can pull stuff out of the boxes and add more pictures.
*update*
(Sold items removed from original post)
Spare wiring harness sold
One ECM sold
Struts/springs sold
Dash clusters sold
*update*
One ECM sold
Struts/springs sold
Dash clusters sold
