Cylinder Leakdown Tester Needed
xxiaze
I recently purchased a leakdown tester from amazon, expecting a basic tool with basic results. I received something that would not properly thread into my spark plug hole.... I’ve always had trouble with the spark plug holes regardless. Walls so tight.
anyways, does anyone know of a decent quality leak down tester that provides consistent results that works properly with our 1.6L motors?
thank you!
I have the OTC 5606 compression tester with all proper adapters to do our cars and many others also. I have owned a lot of OTC stuff and its usually pretty good product. There is also a deluxe kit for $80 OTC-5605.
https://www.amazon.com/OTC-5606-Com...=otc+compression+tester&qid=1586847255&sr=8-2
Then there is Lisle P#20250.. This is another specialty tooL company that makes good stuff also!
https://www.amazon.com/Lisle-20250-Compression-Tester/dp/B0009OMYH4/ref=sr_1_2?crid=2BECOHD128TU9&dchild=1&keywords=lisle+compression+tester&qid=1586847480&sprefix=lisle+compres,aps,174&sr=8-2
xxiaze
xxiaze
Thanks mate 🙏 I’ll just apply that brand to the leakdown tester search. I have a compression tester and am satisfied with its results... but have had horrible luck with the leakdown tester so far. The one I have is garbage.
xxiaze
xxiaze
Ordered up!
