Anyone interested in doing a Death Valley Run in the blistering heat this summer, all in a day (~12hrs.)? Good opportunity to test out your cooling system in ~120deg F +.
Just bought a Mishimoto oil cooler so I am set! Koozy - were you able to install yours without removing the bumper? May need your wisdom for the install.
FWIW, I no longer have the oil cooler. I found there was no need after installing the Mishimoto Radiator and now with the Motorcraft 180 Thermostat. Be careful where you route and how the stainless lines rest against other components. Several people had the line wear through the AC line and cause Freon to leak out. The protective wrap they supply eventually wears through. To prevent chaffing best to wire tie the line to the part so they are stuck together.
