Difference between Focus 15 spokes and the Ford Racing / EAP wheels?
SST
Toronto
was eyeing on some Ford Racing / EAP wheels off kijiji locally and they are impossible to find, but these stock focus wheels seems to be cheap, and look similar.
are they the same? or just paint finish differently?
vs
FiSTerMr
NYC
I think one of them has a 49 offset, not too sure. You can tell there are slight differences, look closely at the lip. nonetheless they are very heavy wheels , probably even heavier than stock
S
SST
Toronto
oh never thought about the weight, is the Ford Racing one still heavier than our stock wheels?
S
SST
Toronto
good to hear its about the same weight.
49 vs 47 offset, i guess its time to run some spacers
Jerickson88
Rock Creek
I think it’s the same damn wheel. I had EAPs on my SVTF and I really want a set on my ST. I don’t care about the weight, they are super sharp. Probably don’t weigh enough to notice a difference unless you’re coming from some 16x7 RPFs or 15” Team Dynamics
FiSTerMr
NYC
On a car like this, even -4 lb a corner can be felt. I noticed it when I went to my first winter set up.
These are not heavy bloated torque monsters, every little bit makes a diff.
That being said, these wheels are much better looking than the stock wheels.
Jerickson88
Rock Creek
I can see that but at the same time are we talking 5lbs a corner or 2? Question though, would the heavier wheel make a smoother ride?
Jerickson88
Rock Creek
This is the EAP Part number
m-1007-s177e
http://focusraceparts.com/index.php?main_page=product_info&products_id=7641
This is the “standard production” wheel for the 2008-2011 (May be a hair off but that year Focus sucked anyways)
https://www.autorimshop.com/ford-fo...MIqZCv0YSA4AIV1cDICh3iZgViEAQYASABEgIWIfD_BwE
Both are +49mm. I do believe these are the same. I’m guessing Ford had an over run on wheels and incorporated them into a different body style.
I am lookin for the 15” meshes that came on the 2005 and up!
In reference to the picture, I’m also 99% sure that the lighting or flash has made the color seem lighter in one pic.
Ford ST
Pleasant Garden
m-1007-s177e
Why do you got to knock my daily driver. I have a 2010.
Jerickson88
Rock Creek
Because Ford is a bastard! They went from the SVTF and turned away without a replacement, much like they are doing now! Although, the 05-07 “ST” with the 2.3 duratec turned out alright. I’m sure the 08 and up were nice but I was out of the market then. I felt abandoned as a hot hatch owner.
Ford ST
Pleasant Garden
This is true. You can also get these wheels in black they come with a Ford racing center cap. I actually have a set of the SVT Focus wheels unfortunately they are out of around, and are very difficult to get balanced. They are black I like them, but unfortunately they are just not truly round anymore. I was going to scrap them after the tires wear out probably 2020. If you ever drive out to NC after I am done with them, you can have them.
Jerickson88
Rock Creek
I may take you up on that! Back in about 2007 those Dark Argent wheels were like $100 each, my 5 spokes were trashed, so I bought a new set of the 15 spokes and some Neo Gens. That was a cool car. At one point I had a test pipe and it made crackles coming off throttle, much like guys do now but without the tune
PunkST
Menasha
The main difference is where the center cap mounts. Iirc the eap wheels have a more pronounced up sweep toward the cap as opposed to the 15 spoke ses wheel. Its only noticable if you have both wheels next to each other.
Same weight and offset otherwise.
Rocketst
Chesapeake, VA, USA
Just be aware these rims aren't tpms compatible and are a violation of the nhtsa rules about tpms. It's the same as for our cats, if the car came with it it is against the law to disable. But, most problematic, it's illegal for a shop to install these on a car that has a tpms sensor so you may have a hard time getting these installed. Check out the tread act. Love the rims though... It's a shame I can't use them.
PunkST
Menasha
Lmfao, i turned that off with forscan. You may have to bolt them on yourself but you should be able to drop of a set of wheels and tires for a mount and balance at just about any reputable shop and ask that no tpms be installed.
Hell i went and got a set of R compounds installed on old focus 16" wheels for autocross right at the dealer where i bought the car from.
MagnetiseST
Dania Beach
Idk why anyone thinks this. My stock TPMS worked just fine.
PunkST
Menasha
Most folks have re used stockers or bought the universal ones. OR turned off tpms with forscan.
Rocketst
Chesapeake, VA, USA
R compounds are not illegal just sticky tires are. As long as the dot stamp is on the tire it's good.
