So I’m thinking of adding a short throw shifter. While the stock is ok, I find the the throws, esp. 3 to 4, a little rubbery. Will a shift kit improve that? Or does only lessen the distance between the throws. Any downside or trade-off? Thanks.
When you say "shift kit", do you mean the
one from Boomba that is both the adapter and shift lever?
I only have the adapter. Outside of shortening the throws, it will feel a little different. But not sure it can cure your perception of "rubbery". My two suggestions for changing the feel:
1 - Heavier shift knob --> Everyone has their personal preference. But with a heavier knob, I find shift feel to be smoother as the weight does a lot of the work.
2 - Changing transmission fluid --> Your car is brand new, so you may not want to do this any time soon. But I recently changed out the stock fluid for Motul 300 and it made a very noticeable difference in feel. You can tell it is a thicker than the stock fluid because everything just feels more lubricated when shifting.
Pretty sure someone in here that has that shift kit will weigh in and let you know how it feels. You may have already done the reading, but if you get deep enough into
this thread you can read some feedback for those that installed it.
