FS Dpro aka Drift Freaq Rear Camber Plates 1.8 degrees of Negative camber for your FiST!
Trader history for Dpro (3)
kivnul
Deer Park, WA
So this year I am running your plates as the only change from last year (same tires even). I now am 2 wheeling during auto cross. So yeah, they do make a difference.
Los Feliz (neighborhood in LA)
Thread Starter #102
so you are running faster times I take it. Are you running a rear sway bar or is that out of class.
kivnul
Deer Park, WA
A touch faster, yes. I am having to adjust how I drive a tad to limit this new behavior. I do not have a rear sway but I do have a Pierce torsion bar stiffener and MeisterR coilovers.
Thread Starter #104
ah nice ya I am thinking about the MeisterR‘s myself I also have a rear sway bar to put on. I noticed tighter entries but more push on exit so I figured putting the sway bar in should dial back in some of the kick out in the rear causing less push in the front.
So while it will be more connected in the rear it will still dive in on the front. I did notice a much higher breakaway point as well.
The Pierce torsion bar in a sense is doing what a sway bar would do as our rear beams are actually twist beams so they do act in a similar fashion to a sway bars
So ya they do alter how the car drives a bit I could see how someone who was used to how the car drove previous might have a problem driving it faster without adjusting how they drive it. Though in the end one should be able to drive the car faster.
I know I noticed immediately that with my car.
Thread Starter #110
Getting the corner balanced right now and these plates put me at 2 degrees! Thanks @Dpro
NIce awesome to hear this.. I specifically worked on the second batch to bring the tolerances up to where it would be 1.8-2 degree negative. Its not as simple as it seems to manufacturer these.
It‘s great to have someone report back on it.
San Jose
Curious about these, wouldn’t adding negative camber on the rear make the rear end less likely to step out, especially during lift off oversteer?
Thread Starter #112
Yes in fact it does it raises your breakaway point much higher. The question is are you aiming to go through corners faster. possibly change your driving technique. Most people that run these in conjunction with a pierce torsion beam brace and or swaybars have reported faster times overall. I know with my own car adding these gave me much faster entry speeds as the rear end did not let go as soon. I then added in a Hotchkis rear swaybar to eliminate possibility of push on the exit and give back a bit of that playfulness9 lift off oversteer) that the car exhibits stock. The result is the car is downright a blast in corners now not to say it was not stock. Though I can honestly say after doing the two in conjunction it makes you even more fearless in a car that already inspired confidence going into and through corners. :ROFLMAO:
Solebury, Pa.
Even if you do not add any bracing, or sway bar in the back, and just increase the spring rate, and matching damper valving rate, whether part of a coil over system, or factory style replacements of the rear suspension (as I plan to do, since high rate sway bars/added beam axle braces in the back can actually become dangerous when driving on gravel/dirt), these plates will help quell excessive lift off oversteer.
Thread Starter #114
ya setting up for gravel and off road can be different. I do know there is at least one person doing rally stuff with my plates. The Autocross guys absolutely love them.
