I'm baffled...changing my oil right now and I filled up my 7 qt drain pan. Coolant level is fine. I don't have a good sense of smell so I can't tell if there is gasoline in the oil. I put 4.5qts in at the last change and haven't lifted the hood since. Is it possible that there could be that much gasoline in the oil? If so, it seems like the smell should be very strong...
I did take it to Ford to have the blend door replaced, they didn't mention adding oil.
Car is running fine, the oil I drained seems normal...
Any thoughts?
Any thoughts?
