Engine Stops
Irish
Illinois
Have any of you experienced that your car suddenly starts to stop while you are driving and some of the unknown signals appear on your dashboard (ABS and Battery)? Is it a computer error of is it the engine?
Do you have any codes set in the engine computer? Does this happen after you fill up on gas? How old is the battery? What is your mileage? What is your vehicle year?
I
Irish
Illinois
No, I haven't set any. It is a 2013 Ford fiesta, if not mistaken battery is almost 2 years. mileage not sure. Though my brother wants me to set an appointment with the dealer to check it but still confused about what really happen.
I
Irish
Illinois
Maybe. because when the car stops and try to start it again but it won't work.
kivnul
U.S. Army Veteran
Deer Park, WA
I would second the grounding issue: I would verify that both battery terminals are cleaned and the wires are securely fastened. There is a wire from the negitive terminal to the firewall that acts as a ground. It is relitively easy to access that spot, unbolt the ground, take some sandpaper to the paint at that spot and get down to bare metal. Rewire it up. It is amazing what odd behaviors this car will get if it is not getting sufficient ground. (For example my sons fiestas audio had bad noise in it. Sandpapering that spot fixed it)
