Evan Purge Replacement Causing Turbo Hiss
Ajsoukey
Davis, CA, USA
Hello,
I just replaced my purge valve on my stock ‘16. Immediately after started to get a hissing similar to my turbo blowoff just in front of the passenger dash. More specifically it sounds like it’s a constant blow off instead of only when I let off the gas. It seems turbo related because it will only occur when I hear the whine of the turbo spooling. I was wondering if the two could be connected at all or if anyone has had the same problem before. Any advice helps.
