Foam Part# ?
Zormecteon
Kelso
If you lift up the hood and look near the windshield base, on the right and left sides, there are intake vents. Around those vents are pieces of FOAM that have adhesive backing. Those pieces are glued? to the vents. Mine are falling off. I know I could get generic foam and shape and stick, but I'm looking for a Genuine Ford Part Number. I can't find it on TASCAPARTS...
Any Idea where to get it, or how to find it?
Zormecteon
Zormecteon
Kelso
Zormecteon
Zormecteon
Kelso
Based on what I'm seeing in those threads, sounds like you buy the full Air Deflector kit which comes with the foam and other bits?
CE8Z-54020C16-A - https://www.fordpartsgiant.com/parts/ford-kit-air-deflector_ce8z-54020c16-a.html (?)
Those look like the parts, assuming they're foam, but when i check "compatibility" it says they don't fit a 2014------?!
But that sure looks right.
. https://www.fiestastforum.com/threads/foam-part.29863/#post-484302
XR650R
Eerie
That foam doesn't exist on mine. Pretty sure they did away with it early on.
I would suspect that it's because they're made of foam exposed to the elements and they just rot away.
