Ford Fiesta ST Speaker Wire Colors
Admin1
Dearborn
  • Fiesta ST Battery Constant 12V+ Wire: Yellow/Red
  • Fiesta ST Accessory Switched 12V+ Wire: Run a primary wire to your steering column and use the violet/green wire in the ignition switch harness. This violet/green wire will provide you with a switched power source.
  • Fiesta ST Ground Wire: Black/Blue
  • Fiesta ST Illumination Wire: Blue
  • Fiesta ST Left Front Speaker Positive Wire (+): White
  • Fiesta ST Left Front Speaker Negative Wire (-): White/Brown
  • Fiesta ST Right Front Speaker Positive Wire (+): White/Violet
  • Fiesta ST Right Front Speaker Negative Wire (-): White/Orange
  • Fiesta ST Left Rear Speaker Positive Wire (+): White/Green
  • Fiesta ST Left Rear Speaker Negative Wire (-): Brown/Yellow
  • Fiesta ST Right Rear Speaker Positive Wire (+): Brown/White
  • Fiesta ST Right Rear Speaker Negative Wire (-): Brown/Blue
