Gauge
Saint Pauly
I've used glowshift in my truck...great gauge...love the ability to set the colors up as you like...plus one here for gloshift
Boston, MA, USA
Just a thought, if you are going to do a symposer delete you can use one of the plugs as a source for a boost gauge as well. The Boomba symposer delete is pre-threaded for it with a plug installed. There are other boost gauges out there that plug in to the OBDII port and get the same sensor reading an accessport could display. http://p3cars.com sells some custom fit gauges for our cars that do this (or can be hooked up to a vacuum block with an electronic sender) and sit in the air vent on the driver side
J
Fresno
Thanks, I checked out the boomba one and it seems pretty great. Especially if I can use that for the gauge.
Alexandria
I have a vacuum source block I never used I can sell you for much less than that. Also look into depo gauges.
