Next week, I'm off to the dyno. I know the owner, I used to test at his old shop Akron Horsepower 10 years ago, now he has a shop in N. Canton called Race Mod. I will be making an appointment next Monday for later in the week. What I plan on doing is getting a base line with the Dizzy tune, then as I add mods update tune then hitting the dyno after each mod to see what it adds or subtracts to the power. I will be posting the results in my build thread. If you have any requests, I will try to accommodate.
The parts I have waiting for install are as follows, Thermal R&D 3"(waiting for delivery), cp-e Ram Air (waiting for delivery), Whoosh hot side, cp-e cold side, Bravo Alfa intercooler, Bravo Alfa fuel pump, HKS BOV, Mishimoto catted down pipe, Garret GT2554r, Pumaspeed quick spool exhaust manifold.
I'm going to install the parts easiest to hardest. The exhaust and intake order of install will depend on which gets here first. I plan on doing the down pipe and exhaust as a unit. Then hot side, cold side, HKS and intercooler as a unit, AEM meth kit, All this leading up to the Garret and Puma. That will lead up to bigger injectors (once we get the data on the Jags), up rated HP fuel pump (also going to test the Jag pump on this), Brava Alpha LP fuel pump, then AUX fuel.
Thats it, open to suggestions, thoughts, opinions and ideas
