Hard going into 1st and 2nd after clutch and slave replacement
Mpumalanga
Hi Team :)
I had an issue with my clutch slave and had it replaced, did the clutch oil and axel seals at the same time. Ford used 75 FE oil which i replace with 2l Ravenol. When going into 1st or 2nd it is scratchy. any guidance what i can check.
Thank you
