Have anyone installed Powerflex handling pack (bushings)
canada
Hi ya'll.
Im wondering if anyone installed the Powerflex handling pack in either duro and can give me a quick review or comments on it? Ride quality or overall worth of the product!
Cheers and thanks in advance
C
canada
Thread Starter #2
Hi ya'll.
I'm installing FA 500 coilovers and adjustable sway bar endlinks. Is it worth changing all rubber bushings to polyurethane or just rubber bushings for what is worned out!?!
Chino Hills
If you're referring to the control arm bushing kit, I can attest to the install and outcome. If you don't have a press, get a really sharp blade and slowly shave the bushing away until you can pop it out with a hammer and socket. The bushings have quite the feedback difference in steering response. Installing the rear caster control arm bushing is a bit more difficult since it will require a press. My suggestion would be to do the bushing install. The rubber will deteriorate much faster than you might expect, poly will handle stress well, and the ride comfort is smooth.
I've never installed the rear torsion beam bushing, but plenty of videos out there to succeed.
Sent from my moto g power using Tapatalk
