Head light removal Help!!
Wichita
So I got the passenger headlight out easy enough but I can not get the drivers side out no matter how hard I move pull it push it or lift it. The other one just took a bit of wiggling and out it came. I assume it's stuck in the clip but I can't see properly but I feel if I pull any more some thing is going to break. As any body got any ideas would be much appreciated.
Thanks in advance
Arlington, VA
I dealt with this exact issue this weekend. There is a little plastic piece under the end closest to the side mirror that holds it in place even once you remove all the screws. You can see it on the passenger side one as well, though that one wasn't as hard for me either. I just slid a panel popper underneath the plastic piece toward the back (right behind where the screw goes) and pushed it backward and it popped right out. A flat head screwdriver would probably work too.
Turbo65
Wichita
Thanks I'll try and put a panel tool under it, I think I have free of the bottom white clip now. What sucks is the other side was just like the video I watched on bumper removal
Turbo65
Wichita
Jeers mate that done the trick
