Did you buy a new dash piece to fit the alpine? If so where did you get it At? Guess I should check your install out first.. lol. I really appreciate your guys response.. I was going crazy..
Installing the alpine the way I did it the first time required using the Metra kit to put the radio where the cd slot was on the factory radio but it required cutting some bracing out including removing some bracing for the factory screen because the hood that goes over the area where the screen was had to be replaced by a hood from a 2011 fiesta.
As everyone has said they don’t like the Metra kit it does not make an exact fit. So I have rethought the install and I am going to install the radio in the top portion where the screen was with a custom kit that I am making.
Then I’m going to put the factory panel with the radio controls and vents back in the car.
I bought an extra sleeve from alpine for the radio to make the kit.
The Metra kit does not work with the factory hood. The hood as I am calling it is the piece that goes on the top of the dash. The Metra kit was designed to work with the standard fiesta without a screen so that’s why you have to get one out of a older fiesta and the hood doesn’t mount in the st because of the screen so you have to cut out a lot of that screen bracing to make it go back in there but when you remove the bracing the older fiesta hood snaps right in.
I believe based on what I’m doing now you could install something with a screen provided you were willing to do the work for the custom kit. With that being said once you remove all that bracings anything will go if you make a custom kit.
If your curious to make a custom kit for a din size radio you just need a sleeve or dash kit and then you use some wood to make a box around the sleeve and cut where you want it to go then fiberglass and bondo sand, paint and your good to go.
If you want to do a double din get a dash kit modify make some bracing attach to dash fiberglass bondo sand paint done.
I’ll post pictures when I’m don’t with the custom kit in the next couple of weeks.
Hope that helps
If you have any questions let me know.
