Help help helphelp help
Katy, TX, USA
Hello guys i need help
New to the forums bought mt 2016 fiesta st about 3 months ago with 33000 miles did my first mod catless down pipe when i was removing heat shield bolts i made the mistake to remove an oil line conected to the block goin to turbo and did not notice drove the car next day lost all my motor oil lost power car turn off on me, Found out my turbo was blown, i put a used turbo yesterday car dont feel the same it feels under power im gettin 20 psi so i know turbo is working could i have damage my engine?
Please help what should i look for
Welcome , well depleting a turbo of oil will destroy stuff and considering thats part of your whole oiling system, you may have caused damaged elsewhere. You should probably take it a professional. As much as we can help someone..in person is much better.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
What is your current oil pressure?
A
Katy, TX, USA
Do uall think is better to repair engine or swap with a low mile one?
Any body know anybody in houston,tx. That know ecoboost engine that can take a look at it to see if is cheaper to do repair or swap engine
maestromaestro
Houston
Houston has a FB FiST club - but, they're quite anal about letting people in: you have to have a "real" FB page. Look them up if you want some "local" advice. Running an engine without oil is a surefire way of having a bad day. The good news is that our engines aren't terribly expensive.
