This probably got messed up a bit when I did the mountune radiator install back in late June but I haven't had any issue with the cable up until this happened and there was no indication of an issue before. Basically, the hood release has no tension on it and, from what two different shops say, I have to break into my own engine bay through the grille because there's no other damn way to do it. The most recent shop I went to has had to do this before and mentioned that replacing the hood release cable would be a good idea while we're at it.
Has anyone else run into this before and if, you did, what was your approach? If anyone has a spare grille lying around feel free to let me know...
And, back in June again, a shop damaged my driver side skirt and popped a few clips off of it. Finally getting around to having the time to resolve that (and bill the shop that caused it) and I wanted to double check the part numbers since the guy said he was just going to take the whole thing off. I've found W716352S300 and W716351S300 of which I would need 9 and 4 respectfully, if I'm reading these diagrams correctly. Can anyone confirm? Thanks
