Humming noise when turning
Whittier
I've started to hear a humming/vibration come from the right/front side of my car but only happens when I'm backing out of my drive way or when I turn the wheel almost all the way right. Started doing it last week and seems to be a little louder. Side note, I have lowered on springs. Car only does it when moving at parking speeds, not under load or turning at regular or high speeds. Any input would help!
zanethan
Charlotte
Does it only do it when you turn to the right? If it's both directions then it might be the power steering system struggling at full lock. Check you fluid and see if you're low.
slowst
Whittier
Yeah it only does it when turning right.
zanethan
Charlotte
Are the the coil overs on the right and left set to the same specs? If so then I'd start to suspect something in the steering rack maybe.
slowst
Whittier
They are just springs, that have been in for about 3 months now with no issues.
slowst
Whittier
Update: So woke up this morning checked the fluid and the upper reservoir for the dot 4 fluid was almost dry so topped it off with some Prestone dot 4, has made the noise gradually less every time I try and force the noise... hopefully the low fluid was the problem
zanethan
Charlotte
If the noise is getting better it's the system bleeding itself. Check the level every few drives to makes sure it still has fluid. Hopefully, no major damage was done.
slowst
Whittier
Definitely, will do. Thanks!
Brooklyn
Isnt the steering electric?
slowst
Whittier
