Thinking I should do a little blue loctite on some of the fasteners, primarily the ones for the turbo elbow, bpv block off plate and possibly the wastegate bolts (that secure it to the bracket).
No that should be adequate* Just NO RED>. Check the Temp rating also ..i think Normal Blue Loctite goes to 300 degrees. But Loctite Blue 2422 goes to 650 degrees. If you want something higher temp
