Jammed
Mr Big
NJ
Shifter keeps jamming in gear can’t shift. Anyone have this issue? Coolerworx
WannabeST
Riverside,CA
Is it stuck in a gear and won't let you shift out? or is this a problem going in and out of gear?
Does it happen all the time or just under bigger loads.
M
Mr Big
NJ
All the forward gears seem to Jam when you sift from 1st, 3rd or 5th. I can shift 1,2 ,4&6th no problem
M
Mr Big
NJ
Have you adjusted the linkages on the Coolerworx so it’s centered perfectly?
The shifter has been in the car for 2 years and about 12k miles no issues. The lock nuts are all tight
