I've decided to finally put together a build thread; so here it is! Lots of detail with plenty of SCCA RallyCross content and all of the custom parts I have built for my car.
2016 Ford Fiesta ST
White Platinum Tri-Coat
Base Model (Ford Racing Recaros Added w/ OEM Airbags)
Current Mileage & Fuel Economy (Updated 11/22/2020)
83,645 Miles
23.5 MPG (Fuelly Data, Mix of Pump Gas and Ethanol Fill Ups)
Current Setup
Powertrain
Stock, Unopened Engine **knocks on wood**
Amsoil Signature Series 5W-30 Synthetic Engine Oil
Turbo Technics S280 Turbo w/ Turbosmart Wastegate Actuator (~15PSIG Spring Pressure)
GoFastBits DV+ Diverter Valve
AET Vudu Ported OEM Exhaust Manifold
Whoosh Motorsports 3" Catted Downpipe
Thermal R&D Full 3" Catback Exhaust
Cobb Exhaust Hangers
Stratified 4-port Auxiliary Fuel Rail (X4TRA) with Split Second controller (95 lb/hr injectors)
Bravo Alpha Low Pressure Fuel Pump (AEM 320-E)
K&N 81-1000 Inline Fuel Filter
ST200 Airbox, whoosh motorsports crossover pipe (cerakoted) & induction hose
Velossa Tech Big Mouth Snorkel (white)
CP-E Front Mount Intercooler
Turbo Technics Hotside Charge Pipe
Zeitronix ECA-2 Ethanol Content Analyzer w/ Gauge
Brisk Racing 2-Step Colder Spark Plugs
Mountune Radiator
Motorcraft 180F Thermostat
Mishimoto Aluminum Coolant Tank (Black)
Tuning & Fuel
Cobb Accessport V3 w/ ProClip Mount
CP-E Custom Tune (Mitch Levy) for TT S280 Turbo w/ Aux Fuel
- Full E85
- 93 Octane
Bosch 3.5 Bar TIP Sensor
AEM 3.5 Bar MAP Sensor w/ CP-E MapTap and JDG Cutom MAP Plug
Drivetrain
CoolerWorx Pro Short Throw Shifter
JDG CoolerWorx Custom Linkage (Carbon Steel, 5/16" Ball Studs)
Raceseng Weighted Shift Knob (Circuit 100 Series)
NoPistons Gas Pedal Spacer (3/8")
CP-E Rear Motor Mount
Vibratechnics Fast Road Engine Mount
Vibratechnics Fast Road Upper Transmission Mount
Wavetrac Limited Slip Differential (To Be Installed)
OEM Clutch
Ravenol 75W-80 Manual Transmission Fluid
Brakes
Motorcraft Front & Rear Brake Pads
Stoptech Front Slotted Rotors (OEM, 280mm)
Ford Focus SVT Rear Brake Caliper Brackets
Stoptech Cryogenically Treated Rear Brake Rotors (Focus SVT, 280mm)
Motul RBF600 Dot 4 Synthetic Brake Fluid
Suspension
Bilstein B6 Front & Rear Struts
JDG Front & Rear 1/4" Spacer Lift (Stainless Steel, 5/8" Overall Lift F/R)
Powerflex Rear Spring Pads
Whiteline Camber Bolts
Dpro Rear Camber Plates
Pierce Motorsports Front Chassis Brace (2-point)
Wheels
Summer: Konig Dekagram 16x8 (Bronze)
All Season: Sport Edition 16x7.5 (Graphite)
Winter: Steelies 15x6 (Black)
Rallycross: Method MR501 VT Spec 15x7 (2), Sparco Terra 15x7 (Bronze, 2)
Current Tires
Summer: Dunlop Direzza ZIII 225/45R16 (24" Tall)
All Season: BF Goodrich Sport Comp 2 A/S Plus 205/55R16 (25" Tall)
Winter: Michelin X-Ice XI3 175/65R15 (24" Tall)
Rallycross: Maxsport RB3D2 185/65R15 (2), Federal G10 Gravel Tire 185/65R15 (2) (24.5" Tall)
Protection
Skid Plate Guy (SPG) Aluminum Engine Skid Plate
NoPistons Evap Canister Skid Plate
Sparco Mud Flaps
Sabelt Front Tow Strap (Yellow)
Lighting
Rally Innovations Light Plate (Black) with Custom Rear Mounting Brackets
Baja Design Squadron Sport Fog Lights (Amber)
Baja Design Squadron Pro Driving Lights (Amber)
Hella Halogen Driving Lights (55w)
Diode Dyanmics LED Reverse Lights
Diode Dynamics LED License Plate Lights
Diode Dynamics LED Interior Lighting
Contura Switch Panel (Cubby Area, 5 Switches) (WIP)
Otrattw Custom Contura Switches (WIP)
JDG Custom Relay Panel (WIP)
Other
JDG Custom Traction Control Auto-Off Module
Mele Design Firm Lightweight Battery Box
XS Power D680 Lightweight Battery
Shaved Grill (ST Logo Painted Semi-Gloss Black)
Semi-Gloss Black Painted Crash Beam (Duplicolor)
Drawtite Trailer Hitch
Lightweight/compact Spare Tire
ST Floor and Cargo Mats
Dark Ice Designs Hood Lift
Interior
Ford Racing Recaro Front Seats
JDG Custom Drift Button (Handbrake Modification)
RAM Ball Phone Mount mounted to ProClip Base
Valentine 1 Gen2 Radar Detector w/ Ram Magnet Mount
Dedicated Android Samsung Phone for V1G2 JBV1 Radar Detector Integration
NoPistons Dead Pedal
Dragy GPS Performance Meter
Ford Focus Leather Adjustable Headrests
Exterior Cosmetic
VelossaTech Wing Risers
2011 Fiesta Tail Lights
Third Brake Light Flasher
Past Setup
Engine
Revo RT330 Turbo
Garrett GTX2860R Gen2 Turbo
Cobb Catback Exhaust (2.5")
CP-E Intake (3")
Cobb Front Mount Intecooler
NGK 6510 1-Step Colder Spark Plugs
Tuning
Stratified Flash Tune for Stock Turbo (93 Octane & E30)
Stratified Custom Tune for Revo RT330 and Garrett GTX2860R Gen2 (93 Octane & E50)
Wheels
Sparco Assetto Gara 16x7 (Graphite)
Tires
General G-Max AS05 205/50R16
BF Goodrich Sport Comp 2 A/S 205/50R16
Firestone Firehawk Indy 500 205/50R16
Custom Parts & Designs
https://www.fiestastforum.com/threads/plug-and-play-traction-control-off-module.18531/
View: https://www.youtube.com/watch?v=ZKWcrsMD24I&feature=emb_title
https://www.fiestastforum.com/threa...ips-tricks-linkage-redesign-discussion.22928/
Drift Button Handbrake Modification
View: https://www.youtube.com/watch?v=Qzl50rKCBYI
2016 Ford Fiesta ST
83,645 Miles
Current Setup
Powertrain
Mountune Radiator
Tuning & Fuel
- Full E85
- 93 Octane
Drivetrain
OEM Clutch
Brakes
Suspension
Wheels
Current Tires
Protection
Sparco Mud Flaps
Lighting
Other
Interior
Exterior Cosmetic
Past Setup
Engine
Revo RT330 Turbo
CP-E Intake (3")
Tuning
Wheels
Tires
