Hi there! Just got my ordered tune from Dizzy (surprisingly quick actually) and Jason has asked me to monitor somethings. He said "
Please also set your AP to log the following parameters:
Accel. Pedal Pos.
Actual AFR
Airflow Mass
Boost Pressure
Charge Air Temp.
~ETC Angle Actual
Engine RPM
Ign Corr. Cyl1
Ign Corr. Cyl2
Ign Corr. Cyl3
Ign Corr. Cyl4
Ign Timing Cyl1
Ign Timing Cyl3
~Load Actual
Octane Adj. Ratio Lrn
~TIP Desired Rel
~Turbo PID WGDC Base X
~Turbo PID WGDC Base Y
Vehicle Speed
~WGDC Actual
Does he want me to log these and send them to him, monitor these things occasionally, or just log them and save the logs in case I need them? Also, I put a little squiggly line next to the things I don't know the meaning of. If you can provide a definition for a simpleton like me, I would appreciate it lol. Thank you.
Accel. Pedal Pos.
Actual AFR
Airflow Mass
Boost Pressure
Charge Air Temp.
~ETC Angle Actual
Engine RPM
Ign Corr. Cyl1
Ign Corr. Cyl2
Ign Corr. Cyl3
Ign Corr. Cyl4
Ign Timing Cyl1
Ign Timing Cyl3
~Load Actual
~TIP Desired Rel
Vehicle Speed
~WGDC Actual
